I am using this flash data storage as reference github.com/.../nRF52-fds-example
Running fds_test_write() below, it writes to a file specified by FILE_ID, REC_KEY but to different record_id all the time. So, when reading back, I will not know exactly which record_id to read back.
static ret_code_t fds_test_write(void)
#define FILE_ID 0x1111
#define REC_KEY 0x2222
static uint32_t const m_deadbeef[2] = {0xDEADBEEF,0xBAADF00D};
fds_record_t record;
fds_record_desc_t record_desc;
fds_record_chunk_t record_chunk;
// Set up data.
record_chunk.p_data = m_deadbeef;
record_chunk.length_words = 2;
// Set up record.
record.file_id = FILE_ID;
record.key = REC_KEY;
record.data.p_chunks = &record_chunk;
record.data.num_chunks = 1;
ret_code_t ret = fds_record_write(&record_desc, &record);
if (ret != FDS_SUCCESS)
return ret;
NRF_LOG_PRINTF("Writing Record ID = %d \r\n",record_desc.record_id);
return NRF_SUCCESS;
Below is the code to read back the record. It reads back all the records belonging to FILE_ID and REC_KEY. What I will prefer is to have a write function that writes to a specific record_id and a read function that reads from a specific record_id. Something like;
write_record(FILE_ID, REC_KEY, record_id);
read_record(FILE_ID, REC_KEY, record_id);
Is this possible with SDK_11 s130 on nRF51-dk?
static ret_code_t fds_read(void)
fds_flash_record_t flash_record;
fds_find_token_t ftok ={0};//Important, make sure you zero init the ftok token
uint32_t *data;
uint32_t err_code;
NRF_LOG_PRINTF("Start searching... \r\n");
// Loop until all records with the given key and file ID have been found.
while (fds_record_find(FILE_ID, REC_KEY, &record_desc, &ftok) == FDS_SUCCESS)
err_code = fds_record_open(&record_desc, &flash_record);
if ( err_code != FDS_SUCCESS)
return err_code;
NRF_LOG_PRINTF("Found Record ID = %d\r\n",record_desc.record_id);
NRF_LOG_PRINTF("Data = ");
data = (uint32_t *) flash_record.p_data;
for (uint8_t i=0;i<flash_record.p_header->tl.length_words;i++)
NRF_LOG_PRINTF("0x%8x ",data[i]);
NRF_LOG_PRINTF("\r\n");
// Access the record through the flash_record structure.
// Close the record when done.
err_code = fds_record_close(&record_desc);
if (err_code != FDS_SUCCESS)
return err_code;
return NRF_SUCCESS;
