I'm creating a simple SPI bootloader without SD for nRF51822 based on this post
The bootloader is connected to Freescale 22F through SPI and it will be without any BLE. The application itself is simple, which is only sending some SPI data back to 22F.
Here's the application:
// Set 16 MHz crystal as our 16 MHz clock source (as opposed to internal RCOSC)
while(NRF_CLOCK->EVENTS_HFCLKSTARTED == 0)
// Wait
init_spi();
while (true) {
spi_tx.data = 123;
spi_send(spi_tx);
nrf_delay_us(10);
IROM1: start = 0x2000, size = 0x39000 IRAM1: start = 0x20000000, size = 0x8000
The bootloader is also a simple one which will just take the application from 22F through SPI and then write the application into flash. Here's the bootloader code:
__asm void bjump(void)
LDR R2, [#0x00002000] ; Get App MSP.
MSR MSP, R2 ; Set the main stack pointer to the applications MSP.
LDR R3, [#0x00002004] ; Get application reset vector address.
BX R3 ; No return - stack code is now activated only through SVC and plain interrupts.
ALIGN
// Wait
init_spi();
#if 1
int count = 200;
while (true) {
spi_tx.data = 234;
spi_send(spi_tx);
nrf_delay_us(10);
count--;
if(count <= 0) {
bjump(); // jump #1
bjump(); // jump #2
init_bootloader();
while (true)
... main loop for bootloader communication with SPI
IROM1: start = 0x0, size = 0x1F00 IRAM1: start = 0x20000000, size = 0x8000
Currently, I put two debugging codes (bjump), one at location #1 and one at location #2. If I enabled the code at #1, the bootloading process will work properly. I.e., it will send the "234" data couple of times and then the data got changed to "123" which is coming from the application itself.
However, if I disabled the jump code at #1 and enabled the code at #2, only the "234" was received by 22F. After that, the application seems to stuck at some loop. When I ran the bootloader with debugger, I can see that it executed the jump command and then pass the PC to the application, but cannot debug further since I can only see the assembly code.
What could have I missed here?
Thanks, -- Steven
