Hi!
Would it be possible to modify the glucose example to save the database records to flash using FDS?
Keeping the overall structure of reading and writing, just changing e.g. the uint32_t ble_gls_db_record_add(ble_gls_rec_t * p_rec)
and uint32_t ble_gls_db_record_get(uint8_t rec_ndx, ble_gls_rec_t * p_rec)
functions to FDS write and read calls.
You could use meas.sequence_number
as FDS key. E.g. in record_add function:
uint16_t file_ID = glucose_file_ID; //Files are groups of records
uint16_t key = p_rec->meas.sequence_number; //identification within file group
and in record_get function use the sequence number/key to find the records requested through the RACP.
Am I missing something crucial that would totally prevent implementing what I am thinking? Is it possible to use the FDS read while being in BLE connection and performing RACP requests? Considering interrupt priority?
