I would like to use the nrf51822xxaa as BLE gateway for an ARM application processor (connected through the UART).
I successfully cross-compiled pc-ble-driver 1.0 for my device. But I have a problem with the ble_connectivity application because every time I get Timeout (Error 0x0D) on sd_rpc_open call (port and uart pins in ble_connectivity app are set correct - checked & tested).
This is how I prepared and compiled with GCC my ble_connectivity app (followed this instructions):
- First of all, I applied SD20_SDK11.patch from the git repository
- I based on example prepared for PCA10028 ser_s130_hci but because of using nRF51822xxAA with 16kB RAM and different UART pins I have made some changes:
- in ble_connectivity_gcc_nrf51.ld changed RAM region from
RAM (rwx) : ORIGIN = 0x20004300, LENGTH = 0x3d00
toRAM (rwx) : ORIGIN = 0x20000300, LENGTH = 0x3d00
- in Makefile changed BOARD from PCA10028 to CUSTOM_BOARD
- in custom_board.h defined my correct UART pins, in my case
#define RX_PIN_NUMBER 5
and#define TX_PIN_NUMBER 6
- added defines
APP_SCHEDULER_WITH_PROFILER
andHCI_LINK_CONTROL
Compilation goes well, everything seems ok, but doesn't work.
Is there something I missed or done wrong?
