nrf-ble-bcast mesh compilation issues
I want to run BLE mesh network example on my Dev board to understand it better. I am running it on SDK v8.1 and using ble_app_proximity example S130.
Following below link: github.com/.../integrating_w_SD_apps.adoc
I am using following keil project in SDK v8.1 ble_peripheral\ble_app_proximity\pca10028\s130\arm5_no_packs
I also added project files to rbc_mesh to proximity example and set up include paths in keil. But when i compile It can not find file spi_slave.h and bootloader_info.h
Compilation Errors: ......\rbc_mesh\src\dfu_util.c(34): error: #5: cannot open source input file "bootloader_info.h": No such file or directory
......\rbc_mesh\src\serial_handler_spi.c(31): error: #5: cannot open source input file "spi_slave.h": No such file or directory
Also, as It asks to edit timeslot_handler.c, but I can not find any file like that.
Can somebody please help me ????
  • You don't need the dfu_util.c anymore so just remove this.
    The spi_slave files can be found under nRF51_SDK_8.1.0\components\drivers_nrf\spi_slave.
    It should ask you to edit timeslot.c and not timeslot_handler.c (which do not exist anymore). I've asked to update the guide.
  • Thank you Ole.
    I tried to follow what you asked me too.. I removed dfu_utils.c and added spi_salve from drivers_nrf
    Before editing timeslot.c I just tried to compile this and got following linking errors.
    Using Compiler 'V5.06 update 1 (build 61)', folder: 'C:\Keil_v5\ARM\ARMCC\Bin' Rebuild target 'nrf51422_xxac_s130' . linking...
    ._build\nrf51422_xxac_s130.axf: Error: L6200E: Symbol UART0_IRQHandler multiply defined (by serial_handler_uart.o and app_uart_fifo.o).
    ._build\nrf51422_xxac_s130.axf: Error: L6200E: Symbol GPIOTE_IRQHandler multiply defined (by serial_handler_spi.o and nrf_drv_gpiote.o).
    ._build\nrf51422_xxac_s130.axf: Error: L6200E: Symbol serial_handler_command_get multiply defined (by serial_handler_uart.o and serial_handler_spi.o).
    ._build\nrf51422_xxac_s130.axf: Error: L6200E: Symbol serial_handler_credit_available multiply defined (by serial_handler_uart.o and serial_handler_spi.o).
    ._build\nrf51422_xxac_s130.axf: Error: L6200E: Symbol serial_handler_event_send multiply defined (by serial_handler_uart.o and serial_handler_spi.o).
    ._build\nrf51422_xxac_s130.axf: Error: L6200E: Symbol serial_handler_init multiply defined (by serial_handler_uart.o and serial_handler_spi.o).
    ._build\nrf51422_xxac_s130.axf: Error: L6200E: Symbol serial_wait_for_completion multiply defined (by serial_handler_uart.o and serial_handler_spi.o).
    Not enough information to list image symbols.
    Not enough information to list the image map.
    Finished: 2 information, 0 warning and 7 error messages.
    "._build\nrf51422_xxac_s130.axf" - 7 Error(s), 1 Warning(s).
    Target not created.
    Build Time Elapsed: 00:00:16
  • It seems like you already use app_uart, which would create a conflict on the serial usage. Unless you need the mesh serial, try to remove any of the mesh serial files. This includes serial_handler_uart, serial_handler_spi, mesh_aci. Also remove the spi_driver file from the SDK, if you remove these.
  • Thank you. It did compiled successfully after trying as you said.
    But How can I test this thing and understand its working ? I want to see the real time data or working example ?
