Hi, I knew I can send multi packets per connection interval. Can I limit 51822 only send "one" packet per connection interval?
With sd_ble_opt_set(...) you can configure the SoftDevice for the type of throughput performance your application demands. If you configure the bandwidh to BLE_CONN_BW_LOW, only 1 packet per connection interval will be sent.
Hi Sigurd, I'm using SDK10's ancs example, I can't find BLE_CONN_BW_LOW. I can find it in SDK11. Is there any other name in SDK10? or SDK10 didn't support that config?
This feature was introduced in SoftDevices S130 & S132 v2.0. What SoftDevice are you using?
I'm using S130 V1. OK, I'll try update to V2. Thanks a lot.
Because of new API calls to the Softdevice in V2, you also need to update to SDK 11 or 12. Here is a link to the compatibility matrix between Softdevice and SDK versions.
