Hi Nordic,
In my project, I have a NRF9160 and a NRF52832 with a ble host/controller stack over SPI HCI on NCS v2.5.2 As soon as I activate the HCI SPI in my project, the...
Hi We're currently utilizing MuRata - MBN52832 Data for BLE and NFC purposes. We're looking to incorporate testing into our production process to measure various RF BLE signal...
Abnormal power consumption is observed after using sd_temp_get to retrieve the MCU temperature on the nrf52840.
**SDK Ver: SDK17
**Source Code:
temperature.c
float...
Dear support team, The j-link firmware of my nRF52840-DK v3.0.1 is no longer available. Please provide the firmware of nRF5340 so that I can repair the DK.
BR,
zero
I have investigated Zephyr's power managemen API and have the a few questions regarding the nRF52840-DK. The nRF52840-DK was powered externally by the N6705B DC power...
Hi
Does Bosch BME68X_IAQ driver support power management? I can choose between 3 different measurement presets in CONFIG, but I would like to measure values in short ...
I have DK of nRF5340, I want to get started with it and create the development env, as well as I need to measure the sleep current for this module?
Any quick tutorial which...
I want to program a nRF52840 as RELAY NODE.
If I set CONFIG_BT_MESH_RELAY=n in prj.conf, with nRF Mesh app on my smartphone I see that Relay feature of the node is...
Hello! We recently acquired a Nordic Thingy:91 for prototyping and it was working great until I came into work this morning and it was no longer showing any signs of life...
I got an error while building the direction finding demo In nRF Connect:
../src/main.c:254:10: error: 'const struct bt_conn_cb' has no member named 'cte_report_cb' 254 ...
Hi Nordic,
We are working with nRF5340 with SDK v2.5.2.
Each time we try to program the board, we get below error.
We do not see this error if we try Erase and Flash option...
I am currently investigating the Bluetooth Low Energy (BLE) PHY modes utilized by our nRF52840 device, which lacks documentation and was programmed by an external...
Hi Nordic,
I am exploring on how to use an ADC module for measuring the battery percentage for my nrf52840. I am working on the nrf connect SDK. Can anyone suggest me a...
Hello.
I am developing an SPI FIFO reading program with a accelerometer. with sdk17.1.0
It runs well on nrf52840 devkit but it stuck at nrf52832 devkit.
And I found...
as mentioned in the title, when using the official vscode extension (nRF Connect for VS Code) for debugging and stopping a debug session, the target state does not get...
I believe that the Nordic fork of hostap ( https://github.com/nrfconnect/sdk-hostap ) has a bug in os.h:
typedef uint64_t os_time_t;
The upstream has that defined as long...
We have designed a custom board and just have started testing. We are observing nRF9160 device is rebooting after every 30 seconds. What could be the reason here....
We are currently developing a WiFi library and just started on implementing HTTPS and ran into some issues. Since we don't have enough flash and memory for using...
