Hi, Im working in nrf9160dk, I'm referring aws iot document there they given a code 6278.aws_iot_tutorial.rar there im getting this error .what i need to do?
Executing task...
I'm currently trying to add DFU OTA in my project.
I had add few lines for enable bootloader and BT OTA to my proj.conf, but keep getting error when building the project...
I have an issue that I don't know how to debug. I take the latest version of Zigbee Light Bulb example code and the only change I make is add CONFIG_ZIGBEE_CHANNEL_SELECTION_MODE_MULTI...
Hi, all. I'm using PPK2 in amper meter mode. Version of SW: - nrf connect for desktop application: v.4.4.1; - power profiler: v.4.0.0. Settings: - sampling parameters: 100...
1) Is it possible to program and read data in nRF5340 using USB lines?
2) Is the below schematic correct for our requirement do we need to add anything else?
I connected the bme680 sensor to my nrf52840 via SPI. In overlay file I applied the following configuration :
During the bme680 initialization, I got the following...
Currently, I am creating firmware that generates an IRQ_DIRECT_CONNECT interrupt at the timing when SPIM4 transfer is completed (ENDTX).
However, the interrupt...
We are looking firmware upgrade through WiFi from third party server. download from server and upgrade. We checked below link. https://developer.nordicsemi.com/nRF_Connect_SDK...
We developed the module that consisted of nRF12540+nRF52833 for connection between the wireless(Bluetooth) and the wire(RS485).
The module can be a Central mode or a Peripheral...
I have developed the VL53L5CX TOF sensor code in nrf52840 in twi_sensor Example and it is working fine
but whenever i merged this sensor code with BLE project multiple_byte_write...
Hi everyone,
I am new here. I wanna develope a module using nrf52833 for observing other bluetooth device like "nrf Connect For Desktop-> nrf connect for desktop bluetooth...
Dear Nordic team,
I'm evaluating nRF5340 Audio DK for the use-case of broadcasting multiple streams; NCS v2.6.0-rc1.
Until now I've succeeded broadcasted 4 streams (LC4...
We are using nRF Connect SDK Toolchain 2.4.2. We want to make rom_reports and footprints but we get the following error:
[09:04:53] Command failed: west build -d...
Hello, Today, I used nRF Connect for Desktop to upgrade nRF Connect SDK to NCS 2.6.0. The nRD Connect for Desktop upgraded fine to v4.4.1. I was able to install NCS 2.6.0...
I am trying to set interrupt processing to the highest priority on Zephyr OS,
but it does not work properly even if I set the interrupt processing priority to...
Good morning
I am looking to purchase for nRF54L kits in order to migrate my existing nrf53832 code.
When would be the kit available for public ? (I understand for time...
Hello, I am currently working on nrf52840 using nrf-sdk v2.2. to build a Matter firmware. I encountered an issue that a small number of chips UART received data incorrectly...
Hello everyone, I am using nrf52810 custom board and SDK17
i installed the uart module as follows. I also installed the relevant drivers. can't get any output when I want...
I am trying to get the TagoIO HTTPS sample to build and run. I have been running and connecting to AWS for years with no problem but a new customer prefers to use TagoIO HTTPS...
