Greetings
I am trying to measure the current consumption of my board (does not use a Nordic SoC), and the power profiler in unison with the NrfConnect SDK app measures current...
Hello! We recently acquired a Nordic Thingy:91 for prototyping and it was working great until I came into work this morning and it was no longer showing any signs of life...
i can't open example blinky for pca1056 in Keil C 5 in sdk _17.1.0
i have installed all package about Nordic but it isn't worked.
Beside, Can i flash code to nrf52840...
Hello, I have recently designed a custom board integrated with nrf7002 and nrf52840 qfaa. However, I'm encountering an issue while trying to program the nrf7002 OTP. The RTT...
NCS v2.6.0
nRF52 DK
central_uart send packet to peripheral_uart, then peripheral_uart send write response packet to central_uart.
How to get the write response...
I'm writing an android application, using no.nordicsemi.android:ble:2.3.1. I connect to the sensor and write 49KB data to it. Before recording, I set the desired interval...
Hello everyone,
I have questions. I am trying to scope 32mhz external clock on osilloscope that gwınstek gds-1062 and I show this two picture. First is at 250ms time/div...
After creating a directory in ncs folder, with cmake and source files, i try to add build configuration in VS code, but after the process of building occurs, the build folder...
Features
nRF52840
nRF52832
System current consumption DC/DC at 3 V
0.5μA at 3V System OFF mode,
no RAM retention
1.5μA System ON mode, no RAM retention...
I ran into a problem with nRF52840 based firmware development
I initialize the RTC with
Prescaler = 0
CC[0] = 0x19fd
I tried clock source synthesized from...
I am thinking of developing it by reusing the nRF5340 DK circuit and the nR5340_Audio sample program. I don't know where the nRF5340's switches and LED pins are assigned in...
I am using nrf5340 Audio DK board. In that board I have flashed a sample firmware of Unicast Gateway.
This firmware is suppose to scan the advertisement and establish...
we are developing custom hard fault handler to get its information during non-debug mode. In order to collect the information in non-debug mode we are trying to store...
We had a strange problem with a test case of ours. We use the radio in 1Mbps BLE mode and send two packets, then receive one packet.
Our test case normally works, but fails...
My setup is a custom board with a nrf5340 which acts as the BLE Central and SDK 2.6.99. When I use a 52833 DK as the peripheral which has the BAS service I can connect and...
Is it possible to combine the BLE Uart example with OTA? Our goal is to change the addresses in the filter (BLE Uart central, static ble_gap_addr_t const filter_addr ), by...
Hi, I'm having trouble finding out which update caused my application to crash. The build works fine with nRF Connect 2.43, but with the latest version (2.6), it doesn't work...
for a development project I need to make a USB device HID. I started from the example project: \v2.6.0\zephyr\samples\subsys\usb\hid so on version 2.6.0 of zephyr...
sdk:17.1 example: ble_app_uart+ secure_bootloader. HI I want to do a demo recently. The application scenario of this demo is that in low-power mode, the RTC wakes up every...
In my setup I have one central where several peripherals are connected. I'm using the Multi-NUS service to communicate from the central to the peripherals. Here...
Greetings
