Hello, Karl Ylvisaker. When I use 52840 scan, I sometimes fail to scan other Bluetooth devices for a long time, but the scan will resume after a long time. Other Bluetooth...
hi
I am developing using nRF52832 and SDK 17.0.1 (NUS).
I configured paring using BLE Name filter...
I can't find the part that modifies the central response...
I would like to be able to dynamically enable & disable APPROTECT from a zephyr application at runtime, not via Kconfig. Is there existing driver support for this feature...
In working thru the Nordic Academy Intermediate lessons on DFU, it was very instructive to use the mcumgr command line interface to see exactly what's happening on the device...
hi
I am configuring a product using nRF52832 and NUS.
This time, I'm trying to view BLE wireless data (raw) from central and peripheral, but I can't find a way to do...
I am using nrf52832 as a peripheral and running SD S112, nordic UART Profile and SDK 17.1.0 on it.
After I start advertisement with the manufacturing data, I...
Hi Nordic,
I am exploring on how to use an ADC module for measuring the battery percentage for my nrf52840. I am working on the nrf connect SDK. Can anyone suggest me a...
I'm attempting to generate a binary blob containing both the S140 SoftDevice (to be placed at address 0x1000 in flash) and the main application firmware (at 0x26000).
I...
hi,I am using the NRF52840, softdevice: s140,
If a Bluetooth host simultaneously connects to multiple Bluetooth peripherals, and the peripherals transmit data to the host...
hello,
I made a development board using the nrf52840 module.
What methods are there to measure power consumption?
I know of two methods: measuring with the Power Profiler...
Hello!
I have a device on which the S25HL01GT memory is soldered. The problem is that I don’t understand how I should work with .dts in order for this memory to work with...
I'm using the custom board of nrf 5340 with 7002.
When I run the sample project of Hello World, the current is about 90 ma,
and I run the sample project of WI-FI Scan...
Hi all,
I'm a beginner of Nordic system, I use nRF52832(PCA10040) to develop my project, here is my properties:
Board: nRF52832 nRF5 SDK Version: 17.1.0 Soft device: S212...
I have a Temperature and Humidity Zigbee Sensor, link is here: https://www.aqara.com/us/temperature_humidity_sensor.html
Now I use nrf52840 kit as coordinator and use the...
Hello.
I'm developing some kind of wearable device with using nRF52832.
I'm using Segger Embedded Studio for developing.
I write my code by modifying ble_app_template...
I'm using the NCS 2.5.2 sdk and nrf 5340 with 7002, and I want to do BLE OTA DFU using external flash.
I've found this guide Add DFU support to your application - Software...
I'm currently working on using a MAX86141 sensor ( datasheet found here ), and I've been running into some issues with communicating with it since this is the first...
I am attempting to work thru the tutorial exactly per the instructions, and I'm stuck in Lesson 1 at
6. Wait for the device to connect to nRF Cloud.
The Cellular Monitor...
The code base is the non_blocking SPI sample code configured for nRF9161DK.
in prj.conf
CONFIG_NRFX_SPIM1 =y
At initialization inside
nrfx_spim_init() this happened...
