Hi Nordic team,
I hope this message finds you well. I am currently working on developing applications for custom boards utilizing the nRF Connect SDK v2.4.0, with a particular...
I am trying to build the Serial lTE Modem example from SDK directory C:\ncs\v2.5.1\nrf\applications\serial_lte_modem in VScode then resulting the error:
-- Found...
Hello Nordic Engineer,
I used SDK17.1.0
First chip is examples \ ble_central_and_peripheral \ experimental \ ble_app_multirole_lesc
Second chip is examples \ ble_peripheral...
Hi, i've been trying to use the external flash memory to store new images for OTA firmware update but i keep getting this error
*** Booting nRF Connect SDK v2.5.2 ***...
I am using nrf52840 and SDK -16.0, I wanted to advertise the data when the device is in BLE 5 (LE CODED PHY). Is there is any examples which updates the data during...
I have ported my 2.5.2 project to 2.6.0 - its not 100% functional but that i because the buttons events are handled slightly differently. Anyways, there is this structure...
Hi Nordic team,
-- Found...
We're using nRF Connect with SDK v2.4.0 (Zephyr). Central and peripheral roles combined.
Custom hardware, with Fanstels module BT840
All was working well, but after extensive...
Good morning!
I hope you will forgive my trivial question but I am a beginner. I don't quite understand the partition structure presented in the "NVS" example. Using the...
I used SDK17.1.0
Hi, We are testing in two cellular service regions, one with LTE-M support and one with NB-IoT support. Following the instructions from this ticket devzone.nordicsemi.com...
I have a project working on Nora B1, which I am testing on nrf5340DK. It is based on the Peripheral UART Sample, programmed with nfr Connect SDK v1.9.1. Now I need...
we've run into an issue using the SPI master (SPIM). We got the NRF5340 connected to our FPGA using 2 spi busses. The NRF is SPI master on one bus and SPI slave on...
I am currently looking into setting up a Matter project (based on the template) and reached ZAP and the required files. As far as I understood, the ".zap" file is the...
I have the task to integrate MCUboot in a project that will be deployed on a nrf5340. I've enabled MCUboot using KKonfig option `CONFIG_BOOTLOADER_MCUBOOT`. According...
We tested the transmitter and found out that it operates only on 700MHz. Why is that?
The other modems operate on at least four frequencies (800MHz, 1.7Ghz, 1.8Ghz, 1.9Ghz...
Procedures to reproduce this issue are as follows.
1. Unzipping caf_flash.zip to C:\ncs\v2.5.2\nrf\samples folder.
2. cd C:\ncs\v2.5.2\nrf\samples\caf_flash
3. west...
Hi, I am currently working with the nRF9160DK board, using SDK version 2.5.1, and I have encountered an issue regarding connectivity to the AWS IoT cloud.
I have successfully...
