Running an nRF52840DK on the zigbee light switch multiprotocol ble sample as a sleepy end device seems to get stuck in the zboss thread. In this state the devkit seems to...
I've made a dongle using the nrf52840, and I'd like this custom device to work with the RSSI Viewer and Bluetooth Low Energy on nRF Connect for desktop; what do I need to...
ncs 2.6.0
I'm encountering a weird bus data error when I'm calling psa_generate_random inside a work queue thread (it has name "api"):
The code I'm running...
We just upgraded to NRF V2.6.0 and ran into the following build error when building the Matter light_bulb sample:
CMake Error at /opt/nordic/ncs/v2.6.0/zephyr/cmake/modules...
I have some questions regarding the RF path of nrf5340-CLAA (WLCSP package):
1. The impedance of the transmission line in the reference design, as calculated using AppCAD...
SDK: 17.1.0
Chip: NRF52832
IDE: Segger Embedded Studio v5.10d
Developing a bluetooth accessory app for a scale on the NRF52832. Using the ble_nus SDK module.
When...
I am trying to build the Serial lTE Modem example from SDK directory C:\ncs\v2.5.1\nrf\applications\serial_lte_modem in VScode then resulting the error:
-- Found...
1. I added an at instruction to the example serial_lte_modem to connect to the nRF Cloud but it always fails. What can I do?
2. The code is as follows:
3. Connection...
Hi ,
I have a little difficulty in using the .a .
I added the following syntax, but this .a was not added in the compilation.Even reported it wrong.
I need to know...
I'm doing the tutorial video of nRF Connect for VS Code part5:Debugging.
https://www.youtube.com/watch?v=IDC2m91xMb0&list=PLx_tBuQ_KSqEt7NK-H7Lu78lT2OijwIMl&index...
I'm running into a similar issue to Case ID 304027 with trying to build the nRF Thread coprocessor project for the nRF5340. I'm able to compile the coprocessor project just...
I put prj.conf files under C:\ncs\v2.5.2\nrf\samples\caf_prj\configuration\nrf5340dk_nrf5340_cpuapp folder. But west build failed with the following messages.
Procedures...
ncs 2.6.0
Just upgraded to NRF v 2.6.0 (Mac OS; VS Code). Our code previous built and ran successfully on our custom board with v 2.5.0 of the SDK.
Now we get the following error...
Hi, i've been trying to use the external flash memory to store new images for OTA firmware update but i keep getting this error
*** Booting nRF Connect SDK v2.5.2 ***...
nRF52840
ncs-v2.5.0-rc2
I am using a GPIO interrupt to trigger a callback on every edge on a particular GPIO. I am then timing the difference in time between...
Hi Nordic team,
I hope this message finds you well. I am currently working on developing applications for custom boards utilizing the nRF Connect SDK v2.4.0, with a particular...
Good Day.
I'm trying to run the "npm1300_fuel_gauge" example on a custom board (nRF52840), but I'm getting errors that I don't know how to fix.
The first thing I did was...
