Is there a call back for config server for ble mesh?
Lets say, when relay mode is set, I can bring that out in a callback to do something?
if a key is bound to...
Dear support team, The j-link firmware of my nRF52840-DK v3.0.1 is no longer available. Please provide the firmware of nRF5340 so that I can repair the DK.
BR,
zero
I have investigated Zephyr's power managemen API and have the a few questions regarding the nRF52840-DK. The nRF52840-DK was powered externally by the N6705B DC power...
I have a SIM card that connects via MQTT from an nrf9160 to a server. (using mqtt sample)
The cell search is slow, but once it connects (after a long time), it stays...
I connected one external BH1749 sensor with nrf5340DK and was testing it with the bh1749 sample code but the sensor is only getting initialized and I am getting [00:00:00...
Hi
Does Bosch BME68X_IAQ driver support power management? I can choose between 3 different measurement presets in CONFIG, but I would like to measure values in short ...
Hi, I try to connect ble devices to my iphone. I can send hid data over bluetooth but virtual keypad is hiding. I cant open it. I tried to send 0x65 data as hid report but...
I've got a product where a GATT server runs on an nRF52832, based on nRF52 SDK (15.x)
It relies on notifications. The client connects, enables notifications, and can then...
We are developing for the NRF5340 and Zephyr (SDK 2.5.0). As we approach the first preproduction run, we are realizing we need a better way to set device names than...
How do I get the value of the characteristic of the service I created? I try to get it with the following code, but the content pointer returned is NULL.
Dear Sir,
We have 4 Nordic devices connected to 1 central. At every 195 to 182 seconds 1 packet is sent from device.
I tried changing the following parameters just to...
BR,
zero
Is it possible to flash the application onto the nRF52840 USB dongle using this method?
https://developer.wirepas.com/support/solutions/articles/77000465762-how-to-flash...
I erase and flash nrf52840 dongle with nrf connect, then I read the value or REGOUT0 and the result is 0xFFFFFFFC that corresponds to Vout = 3V.
I'd like to know in...
I have a custom PCBA with which has the flow of:
- Boot
- Advertise some temperature data read from TWI with a 5 second timeout using `ble_adv_fast_timeout`.
- I then...
NCS v2.6.0
nRF52 DK
central_uart send packet to peripheral_uart, then peripheral_uart send write response packet to central_uart.
How to get the write response...
I have a project working on Nora B1, which I am testing on nrf5340DK. It is based on the Peripheral UART Sample, programmed with nfr Connect SDK v1.9.1. Now I need...
Hi, i wanted to add OTA DFU to an MQTT application i coded using zephyr APIs on my nrf52840DK with nrf7002ek.
The problem is that MQTT takes already a lot of RAM and flash...
I have developed a USB MIDI application, in which I have deployed USB Device functionality through USB C-type connector. However, when I test the USB virtual COM Port...
