Running an nRF52840DK on the zigbee light switch multiprotocol ble sample as a sleepy end device seems to get stuck in the zboss thread. In this state the devkit seems to...
I've made a dongle using the nrf52840, and I'd like this custom device to work with the RSSI Viewer and Bluetooth Low Energy on nRF Connect for desktop; what do I need to...
ncs 2.6.0
I'm encountering a weird bus data error when I'm calling psa_generate_random inside a work queue thread (it has name "api"):
The code I'm running...
We just upgraded to NRF V2.6.0 and ran into the following build error when building the Matter light_bulb sample:
CMake Error at /opt/nordic/ncs/v2.6.0/zephyr/cmake/modules...
I have some questions regarding the RF path of nrf5340-CLAA (WLCSP package):
1. The impedance of the transmission line in the reference design, as calculated using AppCAD...
SDK: 17.1.0
Chip: NRF52832
IDE: Segger Embedded Studio v5.10d
Developing a bluetooth accessory app for a scale on the NRF52832. Using the ble_nus SDK module.
When...
I am trying to build the Serial lTE Modem example from SDK directory C:\ncs\v2.5.1\nrf\applications\serial_lte_modem in VScode then resulting the error:
-- Found...
I'm doing the tutorial video of nRF Connect for VS Code part5:Debugging.
https://www.youtube.com/watch?v=IDC2m91xMb0&list=PLx_tBuQ_KSqEt7NK-H7Lu78lT2OijwIMl&index...
I'm running into a similar issue to Case ID 304027 with trying to build the nRF Thread coprocessor project for the nRF5340. I'm able to compile the coprocessor project just...
I put prj.conf files under C:\ncs\v2.5.2\nrf\samples\caf_prj\configuration\nrf5340dk_nrf5340_cpuapp folder. But west build failed with the following messages.
Procedures...
ncs 2.6.0
Just upgraded to NRF v 2.6.0 (Mac OS; VS Code). Our code previous built and ran successfully on our custom board with v 2.5.0 of the SDK.
Now we get the following error...
Hi, i've been trying to use the external flash memory to store new images for OTA firmware update but i keep getting this error
*** Booting nRF Connect SDK v2.5.2 ***...
nRF52840
ncs-v2.5.0-rc2
I am using a GPIO interrupt to trigger a callback on every edge on a particular GPIO. I am then timing the difference in time between...
Hi Nordic team,
I hope this message finds you well. I am currently working on developing applications for custom boards utilizing the nRF Connect SDK v2.4.0, with a particular...
Good Day.
I'm trying to run the "npm1300_fuel_gauge" example on a custom board (nRF52840), but I'm getting errors that I don't know how to fix.
The first thing I did was...
Why is the build and flashing so slow with the nRF5340 and Zephyr? Is there anyway to make it more reasonable?
I have been doing embedded for years and I have not seen a...
I was trying to figure out what what code was being ran before main() function. Specifically the code was not getting to my main() function and was stuck in the cpu idle code...
