i can't open example blinky for pca1056 in Keil C 5 in sdk _17.1.0
i have installed all package about Nordic but it isn't worked.
Beside, Can i flash code to nrf52840...
Hello, I have recently designed a custom board integrated with nrf7002 and nrf52840 qfaa. However, I'm encountering an issue while trying to program the nrf7002 OTP. The RTT...
NCS v2.6.0
nRF52 DK
central_uart send packet to peripheral_uart, then peripheral_uart send write response packet to central_uart.
How to get the write response...
I'm writing an android application, using no.nordicsemi.android:ble:2.3.1. I connect to the sensor and write 49KB data to it. Before recording, I set the desired interval...
Hello everyone,
I have questions. I am trying to scope 32mhz external clock on osilloscope that gwınstek gds-1062 and I show this two picture. First is at 250ms time/div...
1. In ncs v2.6.0 example serial_lte_modem, the level of the P0.26 P0.27 I/O port on the PCA10090 DK board is measurement 0V or 0.8V . Set the high level, normal should...
Hi i am trying to get fw encryption to work for my dfu with mcuboot for nRF9160DK.
I have created a child_image folder with a mcuboot.conf where i have put:
and then...
Accidentally used a 9V power supply. Board does not flash anymore.
Can still connect to com ports, and onboard led lights up.
Is the board fried or is it stuck in a memory...
I'm using the nRF52840 and the nRF5 SDK 17.1.0.
I can enable extended advertising with the following program,
but my scanner is unable to scan the extended packets....
Hello Nordic Semiconductor Support Team,
We are trying to update application using DFU. We use bootloader, BLE 5 long range coded phy. DFU is not successful, please find...
Hi Team,
Can you please provide your inputs here.
1. Is the nRF9160 SLM supports NIDD(non-ip data delivery)? If yes, can you please provide the AT commands to configure...
I'm looking to create a custom board with MDBT50Q-1MV2. Can I directly power it from a LiPo battery (3.7V - 200mAh) only to the VDDH pin? My board is very compact, so I want...
Hello We have nrf5340 min development kits. I am trying to compile the periphal_Ibs example in SDK 2.5.2 and throw it into application and network cores. While I can upload...
I believe that when the nRF5340 operates in LE-Audio CIS mode, the Gateway and Headset are connected, but where is the bonding information set in the source?
Greetings,
After migrating to the NCS v2.5.2, I noticed a warning that recommends using static partition management (which I have also confirmed is recommended by other...
Hi, I am developing an application to read the ADXL355 via SPI. I have not been able to read the register of my accelerometer. And I don't know why. I tried reading the register...
I have a question regarding automating the download process of certificates and software for mass production apllications that need to communicate with an AWS cloud...
I'm facing connectivity issues with my nRF9160DK board,SDK Version: 2.6.0,Modem Firmware Version: 1.3.6.while trying to connect to AWS IoT using the sample code provided...
I got an error while building the direction finding demo In nRF Connect:
../src/main.c:254:10: error: 'const struct bt_conn_cb' has no member named 'cte_report_cb' 254 ...
i have a custom board that uses a nrf5340 that has been hardware modified so i can work again on getting my board to draw the mimimum power from the battery.
i have a PPK2...
