I have a custom board and using an external LTE antenna. Please assist me with the configurations to connect to the internet. I once connected with the following but...
I have read some of the Asset Tracker documentation and noticed there is a nice implementation for operating LEDs in the UI module. This seems straightforward for GPIO control...
Hi
at embedded world nordic presented a camera demo similar to this:
https://www.youtube.com/watch?v=mkYzTxRO1-w
Where can I find the repo for that (app and firmware...
I've got a product where a GATT server runs on an nRF52832, based on nRF52 SDK (15.x)
It relies on notifications. The client connects, enables notifications, and can then...
I am using the GUI app.overlay program to modify the pin locations. I changed the UART0 pins to be P0.00 to P0.03 (from P0.05 to P0.08) so I could free up the default pin...
Hi
I struggle with my external QSPI flash and power consumption of our custom board (at least I think that would be the problem with too high idle power consumption)....
I am in the process of making a custom service for a peripheral I am developing. I have some data that I would like to have in the same characteristic because it will be retrieved...
1. In ncs v2.6.0 example serial_lte_modem, the level of the P0.26 P0.27 I/O port on the PCA10090 DK board is measurement 0V or 0.8V . Set the high level, normal should...
Hi all,
I am trying to flash the nRF 5340 Audio DK boards with the nRF5240_audio sample. When using the buildprog.py script to flash my three boards, the script fails due...
Hello, I am trying to communicate with a Bosch BMI 270 device( datasheet ) using the nrf5340dk. I macgyvered something together from the bmi270 file in the zephyr/sensor folder...
We are currently developing a WiFi library and just started on implementing HTTPS and ran into some issues. Since we don't have enough flash and memory for using...
This is my first time taking a crack at embedded wifi, and I'm currently creating multiple wireless devices to pair with a usb dongle. The Antenna prototype is being...
Hi
Hello Devzone Community,
I try to redo the CRC check of an incoming IEEE 802.15.4 frame in software after manipulating certain positions.
Since the check of the Frame...
Am Implementing Zigbee on NRF52840 chip with help of VS Code.
Zigbee Stack : 2.5.2
I configured nrf52840 DK as Zigbee network coordinator and another custom made...
I am migrating one of Segger Embedded Studio based project to NRF Connect SDK for nrf53 series of board.
I migrated the function that uses GPIOTE feature using relevant...
I'm trying to merge together a couple of sample projects to make a prototype (in particular, the LTE-BLE gateway, and AWS-IoT samples) - to run on the nRF 9160DK...
Designing a board with limited space (35-40mm) and need a chip antenna recommendation for the RF transceiver.
Anyone have experience with the Johnson Technology 2450AT18B100...
I have a device that runs NCS 2.0.2 on an nrf5340 and have an occasional issue with service discovery.
I have recently found that after calling sys_reboot() on my device...
