Greetings.
I have a question that I hope someone can help me with. Recently, I've been working with the HX711 sensor to weigh with a certain precision. I have a custom board...
Hi Devzone,
On my nrf52840-based custom board, I am implementing the scanning of devices broadcasting the Heart Rate service while advertising a custom service and connecting...
Dear Support Team,
Hardware : nRF5340 Custom board
Software : nRF Connect SDK v2.2.0
I have implemented OTA FW update for nRF5340. I've used multi-image simultaneous...
we are facing an issue of loading the application written with nRF Connect SDK to the nRF52840 which has nRF5 SDK's secure bootloader. Update process should be performed...
Unable to use uart ,I2c,SPI together as shown in the error message. I am attaching the dts overlay file
Is there any way to use all UART,SPI,I2C together. Please let me...
we can't open docs.nordicsemi.com in chrome without setting it to: Sites can send pop-ups and use redirects
We don't want to do that for all sites, so we tried adding...
hello Nordic
i am working with ncs v2.5.0 with nrf52840
i am using lfs to save the device configurations in a file
when reading this file i need to allocate a buffer...
Hi
I struggle with my external QSPI flash and power consumption of our custom board (at least I think that would be the problem with too high idle power consumption)....
Hi, I'm having trouble finding out which update caused my application to crash. The build works fine with nRF Connect 2.43, but with the latest version (2.6), it doesn't work...
We've been trying to implement a custom hardfault handler on Zephyr, for a custom board based on nRF52833.
According to Zephyr, also according to one old post on this...
Hi, I am looking at the documentation of the fuel gauge API, specifically at "nrf_fuel_gauge_process" ( https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrfxlib...
I am trying to run the Direct Test Mode on a custom board. We have two boards revisions, one with a nRF52832 and one with a nRF52811. I managed to build the DTM for...
I'm working on an application where we're implementing the nPM1300 and utilizing the fuel gauge algorithm to estimate battery life. Interestingly, the results that...
Hey I have a question regarding the setup described in the title. I have an application built upon the "Throughput Sample" of Nordic Semiconductor. To get a farther Distance...
Greetings.
Hi, I am developing hid device using nrf5 SDK. Iphone virtual keyboard does not shown when my hid device connected. What should I do? Which command Ihave to send Iphone over...
I have a custom board using 2 fanstel modules one for the nrf5340 and one for the nrf7002. I am having an issue where about half the boards stop scanning at the exact same...
hey! So i require some guidance regarding the implementation of system ON low power mode in my sdk. 1. I have configured interrupts for all button press, so that the interrupt...
Very new to Zigbee. Trying to use nrf 5340 dk as a Zigbee Coordinator to connect to a Thirdreality and a Sonoff PIR motion sensor. No modification (expect adding...
Hi all,
I'm a beginner of Nordic system, I use nRF52832(PCA10040) to develop my project, here is my properties:
Board: nRF52832 nRF5 SDK Version: 17.1.0 Soft device: S212...
The code base is the non_blocking SPI sample code configured for nRF9161DK.
in prj.conf
CONFIG_NRFX_SPIM1 =y
At initialization inside
nrfx_spim_init() this happened...
