I was just updating a the nrf Connect toolchain version from 2.5.2 to 2.6 and got this error message:
I did cherry-pick one display driver, but am not even using the...
I cannot connect to the NB IoT in Serbia with an iBasis SIM card. This is a big limitation for my dev work because I can't test any part of the software that talks...
Hi nordic team.
im devolep a keyboard using ncs sdk by nrf52840.frist step,i want to Implement a function that my keyboard can be connected to three Bluetooth hosts at different...
Hello, I am trying to get the asset tracker v2 working on the DEV board nRF9151-DK.
I have got the asset tracker v2 to compile , and also started the process with the at_client...
I recently bought this display that is 64x32 pixels and uses the SSD1306 driver . When running the LVGL Basic Sample with the Zephyr ssd1306 _128x64 shield , the display works...
Occasionally over the years we see suggestions to turn off and turn back on the undocumented power control bit for various peripherals to get around typically unexpectedly...
We had some trouble doing the certification of Tepec, Telec certification requires the RF power accuracy of ±3.8dB , while it is ±4dB in spec。Do you have any good advice
I have installed the nRF Connect SDK v2.0.0 with Visual Studio and can now successfully, build, flash and run the nrf9160 at_client sample application. But when I try...
Hi nordic team.
We have a project based on nrf5340 audio demo,Now we upgrade SDK from NCS2.4 to NCS2.6.
But when I built the DFU, I found that FLASH was not enough
I know this problem...
Hi Nordic Team,
I've got the nrf coded phy hr example working using 1.5.1 nRF Connect SDK, with the peripheral and central sides running on a couple of nRF52840-DK's.
We're using the nRF52840 with Zephyr in the nRF Connect SDK. Our current firmware build is using the SDK v2.3.0.
For some important BLE links we're using the Coded PHY ...
Hi all,
Can someone refer me to a document that details this:
What is the product life expectancy for the nRF52840 from 2024? At least another 10 years?
Thanks!...
I am recently trying to get up and running with the nrf9160-DK and have been unable to flash the board successfully even with the Quick start (v0.2.6) app in nrf Connect....
I am attempting to work thru the tutorial exactly per the instructions, and I'm stuck in Lesson 1 at
6. Wait for the device to connect to nRF Cloud.
The Cellular Monitor...
