The PPK2 is always on COM4 on my Windows 11 machine, and I can't seem to change it. I bought a 2nd PPK2, and when I plug them both in, they are both on COM4. There is no ...
Greetings.
This a follow-on to my prior question about the sample app "peripheral_lbs."
The program obtains a value for variable "led_state" in response to a user keystroke...
I have new Thingy 53. Default Edge Inpulse demo works without any problem. But I have problem with Weather Station demo.
First I tested Zigbee version. After flashing using...
Hello I am utilising the nrf5-sdk and have used the ble_peripheral/ble_app_uart example as a reference. I am using a 2MBPS PHY, an ATT MTU of 247, and a connection interval...
Hi Nordic,
I am coding a program (TCP client) sending an array of bytes to a server over TCP. There is no error during the building process. And, there is also no error...
Hi everyone,
In a project, i am trying to use only channel 38 for extended long range advertising.
Is it possible select only one advertising channel using channel masks...
Hello All,
I am brand new to ZigBee so I apologize for my ignorance. I am developing a product that will use the nRF5340 for the coordinator, router and end devices (but...
I'm getting timeout errors when trying to program a Thingy:91 with a J-Link Pro PoE on macOS on an ARM Apple M3 Max.
Here's the command and error message:
I get the...
Hello, and thank you for your time. We have designed an NPM1100 into a product, and are unclear on if the behaviour of the charge pin is correct (nor indeed what exactly is...
For reasons beyond my control I need to do some changes to a nrf9160 project that was developed using nrfConnect v1.2.1. I know the ideal situation is to upgrade it to the...
Greetings.
I'm currently working on using a MAX86141 sensor ( datasheet found here ), and I've been running into some issues with communicating with it since this is the first...
Our team has encountered an intermittent issue when attempting to connect to our nRF device (nRF52833) using the nRF Connect Desktop BLE app. This issue does not occur...
Hello, we have a product that uses the NRF52832. We recently detected that the device will randomly increase its current consumption by about 260uA during sleep mode. Once...
1. In ncs v2.6.0 example serial_lte_modem, the level of the P0.26 P0.27 I/O port on the PCA10090 DK board is measurement 0V or 0.8V . Set the high level, normal should...
1. am currently using the nrf9161_dk. and have not modified the modem FW in anyway.
2. I am using the vscode extension provided by nordic to build/run this sample
a, i...
