Our product need CE approval. For that the radio must be set into an active transmitting mode among other. I have read the radio_test example is a good option.
To get a...
Greetings.
I have a question that I hope someone can help me with. Recently, I've been working with the HX711 sensor to weigh with a certain precision. I have a custom board...
Hi Devzone,
On my nrf52840-based custom board, I am implementing the scanning of devices broadcasting the Heart Rate service while advertising a custom service and connecting...
Dear Support Team,
Hardware : nRF5340 Custom board
Software : nRF Connect SDK v2.2.0
I have implemented OTA FW update for nRF5340. I've used multi-image simultaneous...
we are facing an issue of loading the application written with nRF Connect SDK to the nRF52840 which has nRF5 SDK's secure bootloader. Update process should be performed...
Unable to use uart ,I2c,SPI together as shown in the error message. I am attaching the dts overlay file
Is there any way to use all UART,SPI,I2C together. Please let me...
we can't open docs.nordicsemi.com in chrome without setting it to: Sites can send pop-ups and use redirects
We don't want to do that for all sites, so we tried adding...
I'm trying to use the Observer example in zephr-sdk-0.16.5 to work with beacons that only use long range coded phy mode. I've updaed prj.conf to take what I believe to be...
To get a...
Hi all,
NRF5340 NRF Connect 2.6.0
We would like to perform the following operations on the NRF5340: * Read FICR.DEVICEADDR (BLE random MAC is also fine). * Set the BLE...
I have a lis3dh sensor where I want to configure the interrupts. I am currently struggling to extract the information from the irq-gpios phandle to the c driver. I went through...
I'm working with nRF5340 Audio DKs.
I'm able to successfully run the audio example in BIS mode (with gateway and headset devices).
My goal is to open another BT...
hello Nordic
i am working with ncs v2.5.0 with nrf52840
i am using lfs to save the device configurations in a file
when reading this file i need to allocate a buffer...
Hello everyone! I'm trying to implement the usage of accelerometer LIS3DH on a custom board. My board has nRF52832 microcontroller as the brain and a few ICs for different...
Hi
I struggle with my external QSPI flash and power consumption of our custom board (at least I think that would be the problem with too high idle power consumption)....
Hi, I'm having trouble finding out which update caused my application to crash. The build works fine with nRF Connect 2.43, but with the latest version (2.6), it doesn't work...
We've been trying to implement a custom hardfault handler on Zephyr, for a custom board based on nRF52833.
According to Zephyr, also according to one old post on this...
Hi, I am looking at the documentation of the fuel gauge API, specifically at "nrf_fuel_gauge_process" ( https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrfxlib...
I am trying to run the Direct Test Mode on a custom board. We have two boards revisions, one with a nRF52832 and one with a nRF52811. I managed to build the DTM for...
I'm working on an application where we're implementing the nPM1300 and utilizing the fuel gauge algorithm to estimate battery life. Interestingly, the results that...
Hey I have a question regarding the setup described in the title. I have an application built upon the "Throughput Sample" of Nordic Semiconductor. To get a farther Distance...
