hi
I am developing using nRF52832 and SDK 17.0.1 (NUS).
I configured paring using BLE Name filter...
I can't find the part that modifies the central response...
I would like to be able to dynamically enable & disable APPROTECT from a zephyr application at runtime, not via Kconfig. Is there existing driver support for this feature...
In working thru the Nordic Academy Intermediate lessons on DFU, it was very instructive to use the mcumgr command line interface to see exactly what's happening on the device...
hi
I am configuring a product using nRF52832 and NUS.
This time, I'm trying to view BLE wireless data (raw) from central and peripheral, but I can't find a way to do...
The code base is the non_blocking SPI sample code configured for nRF9161DK.
in prj.conf
CONFIG_NRFX_SPIM1 =y
At initialization inside
nrfx_spim_init() this happened...
I am using nrf52832 as a peripheral and running SD S112, nordic UART Profile and SDK 17.1.0 on it.
After I start advertisement with the manufacturing data, I...
I'm attempting to generate a binary blob containing both the S140 SoftDevice (to be placed at address 0x1000 in flash) and the main application firmware (at 0x26000).
I...
Very new to Zigbee. Trying to use nrf 5340 dk as a Zigbee Coordinator to connect to a Thirdreality and a Sonoff PIR motion sensor. No modification (expect adding...
hi
Hi all,
I've been trying to get the samples/sensor/lsm6dsl example working with the nrf52840-based Xiao BLE Sense and have had no luck.
I guess that it's due to the power...
Hi there!
I am trying to make an application that plays an audio sample to a BLE speaker (another nRF5340 running as headset) where the audio sample is in memory. I have...
hi
in prj.conf
i have a custom board that uses a nrf5340 that has been hardware modified so i can work again on getting my board to draw the mimimum power from the battery.
i have a PPK2...
I...
I need to update a custom bootloader from the main application running on an nRF52840. The bootloader is contained in 0xF0000 to 0xF90D7 in internal flash, and the S140 SoftDevice...
We are developing for the NRF5340 and Zephyr (SDK 2.5.0). As we approach the first preproduction run, we are realizing we need a better way to set device names than...
Hello my friends,
we have a custom board which includes an nRF52832 being chained to SKY66112-11 FEM. Investigating the radio.c file in the radio-test example, I realized...
I'm currently working on using a MAX86141 sensor ( datasheet found here ), and I've been running into some issues with communicating with it since this is the first...
