Hi
I am stuck using a proximus M2M sim card with the AWS-IoT sample. I did get it working with an Ibasis sim card but now I want to use a Proximus M2M sim card but I keep...
Hello Team,
I have been using a NRF52840DK to program external boards. Recently it started misbehaving and will not detect external boards connected to it. I would like...
Hi all,
I am trying to flash the nRF 5340 Audio DK boards with the nRF5240_audio sample. When using the buildprog.py script to flash my three boards, the script fails due...
Using the official nRF Connect for VS Code extension sometimes when debugging and hitting a fatal error, no backtrace is shown (backtrace seems to be mostly garbage):
Hello, I am trying to communicate with a Bosch BMI 270 device( datasheet ) using the nrf5340dk. I macgyvered something together from the bmi270 file in the zephyr/sensor folder...
I have a lis3dh sensor where I want to configure the interrupts. I am currently struggling to extract the information from the irq-gpios phandle to the c driver. I went through...
In my project I use MPSL for a combination of BLE, ESB and flash sync. The BLE/ESB timeslot handling was implemented following this example: https://github.com/too1/ncs-esb...
I am developing a custom nrf5340 board design, that is using the BL5340PA external antenna module to implement the nrf5340 chip in the design. The BL5340 module allows all...
Hi, I recently installed the last version of the SDK v2.5.2 and when I try to build the sample direction_finding_central I am getting the following error
I am running...
Hi
Hi all , I 'm using NRF52840DK and I want to use RTT to print logging , but I configured a lot of different configs and I can 't print any information in RTT after all . ...
I am trying to read acceleration values from an acceleration sensor (IIM-42652) via SPI with nrf52832 as the SPI master. I created it based on the spi_pca10040 example,...
Hi there!
I am trying to make an application that plays an audio sample to a BLE speaker (another nRF5340 running as headset) where the audio sample is in memory. I have...
We are developing a custom board having nrf9160 cellular modem and we are using serial ltm application in it.
in serial ltm application there is pin selection...
Hi
I am working on a high throughput application.
I use this function to send the notifications: bt_gatt_notify_cb()
Am I right that this function has an internal queue...
I am attempting to work thru the tutorial exactly per the instructions, and I'm stuck in Lesson 1 at
6. Wait for the device to connect to nRF Cloud.
The Cellular Monitor...
Hello Team,
Hello everyone,
I'm working on a Zigbee project that has the Thingy:53 as an end node. The program of the Thingy is a variation of the Zigbee Weather Station .
I'm measuring...
Hi there,
Zephyr has ability for an Application version management . Based on this, I have created a "Version" file, without any file name extension (like .txt).
Now...
