hi support team,
how to use flash partial operation for nrf sdk 17.1 and soc 52840? i have tried below code, but it still stop usb to receive data from pc very quicky, for...
I have the task to integrate MCUboot in a project that will be deployed on a nrf5340. I've enabled MCUboot using KKonfig option `CONFIG_BOOTLOADER_MCUBOOT`. According...
I'm using an nrf52833 with SDK 17.1.0 and was looking at the peripheral/libuarte example. I have a question regarding the following code snippet
Can someone explain...
1. The same program, same configuration, after flash to the chip, runs normally
2. Starting debug mode, unable to execute, as show in the figure
3. When different configurations...
Hi
I use different UUID setting , setting 2 on any compiled warning , but setting 1 has compiled warning .
below is UUID:
setting 1 :
#define BT_UUID_CUSTOM_SERVICE_VAL...
Hello, I've trying to build BLE and MCUBoot Bootloader for a nRF52840 board (Particle Xenon) from the nRF Connect sample "Peripheral LBS". Without MCUBoot Bootloader, the...
I am currently having an issue with my custom board.
I am getting CEREG 4. it is difficult to tell from the documentation if this is:
4 – Subscribe unsolicited...
We are using modules from nRF52 and nRF53 family, and trying to develop our own cross-platform application on Android/Windows/iOS. Do you have any suggestions or example...
Dear Support Team
My goal is to build an application for two targets. The targets are an nrf9160 and a simulation target for running it natively on Linux (currently trying...
Hi there,
I have developed an APP on android with flutter and ble_reative package. I am using the notification mode and the communication between our sensor (via nRF52840...
hi support team,
Hi, i wanted to add OTA DFU to an MQTT application i coded using zephyr APIs on my nrf52840DK with nrf7002ek.
The problem is that MQTT takes already a lot of RAM and flash...
Currently, I am creating firmware that generates an IRQ_DIRECT_CONNECT interrupt at the timing when SPIM4 transfer is completed (ENDTX).
However, the interrupt...
Hello. In the BLE software under development, the device uses nRF52840 and uses s140 v7.2.0.
Please tell me the processing time for interrupts used in SoftDevice.
According...
I am currently working with a couple of nRF52833 development kits.
My software is based on the bluetooth mesh light & light switch examples and extends them by...
Hi!
I have a W25Q128 with QSPI interface attached to my board.Using the litlleFS file system, about 27KB files are written every 1s.I was stunned by the write speed, it...
Hey, after starting advertisement I see this error log from hci_core [00:00:00.029,815] <wrn> bt_hci_core: opcode 0x2027 status 0x12 [00:00:00.029,846] <err> bt_id: Failed...
