I'm using the custom board of nrf 5340 with 7002.
When I run the sample project of Hello World, the current is about 90 ma,
and I run the sample project of WI-FI Scan...
We are interested in the NPM1300, but I would like to know the standby or basic current consumption of the buck converters VOUT1 and VOUT2 when there is no load, with...
I configured the Gpio 8 as the Rx of UART. When the UART is Idle, I need to configure the G pi o 8 to be an interrupt pin.
This configuration is fine at all times except...
I'm currently working on using a MAX86141 sensor ( datasheet found here ), and I've been running into some issues with communicating with it since this is the first...
We have a project based on nrf5340 audio demo,Now we upgrade SDK from NCS2.4 to NCS2.6.
But when I built the DFU, I found that FLASH was not enough
I know this problem...
I have discovered a bug in the fota_download.c file contained in the SDK. I am attempting to cancel the FOTA update separately within my application code, and it goes...
Hello thats my code
and for a 2 days im completely stuck with reading data from LIS3DH, i guess my functions for writing and reading are fine. my read buff is just uint8_t...
I'm upgrading our application from v2.3.0 to v2.5.0 and I ran into an issue where I can't even get the code to compile any more.
We are using USB mass storage with...
I am trying to read acceleration values from an acceleration sensor (IIM-42652) via SPI with nrf52832 as the SPI master. I created it based on the spi_pca10040 example,...
Hello, I am currently working on nrf52840 using nrf-sdk v2.2. to build a Matter firmware. I encountered an issue that a small number of chips UART received data incorrectly...
Hello, I have recently designed a custom board integrated with nrf7002 and nrf52840 qfaa. However, I'm encountering an issue while trying to program the nrf7002 OTP. The RTT...
I have an old nRF9160DK from few years back (v0.8.2). I got busy with other things and was not able to work on it.
Now I'm trying to update the modem firmware to the...
Hi Nordic
It has not be found much in Nordic documentation about sniffing/monitoring over-the-air communication of Matter.
Any recommendations are appreciated.
Or, would...
I'm getting timeout errors when trying to program a Thingy:91 with a J-Link Pro PoE on macOS on an ARM Apple M3 Max.
Here's the command and error message:
I get the...
I am writing to seek assistance with an issue I've encountered while attempting to create a modem trace on my nRF9160DK board.
When flashing my asset tracking code...
The Central device is using Resolvable Private Addresses.
Even though private_addr_cycle_s is set to BLE_GAP_DEFAULT_PRIVATE_ADDR_CYCLE_INTERVAL_S (15 minutes),
When observed...
We have one customer having two CoAP hosts and some CoAP clients in the form of wireless sensors. The sensors are paired to a single host. The pairing is actually in...
