Abnormal power consumption is observed after using sd_temp_get to retrieve the MCU temperature on the nrf52840.
**SDK Ver: SDK17
**Source Code:
temperature.c
float...
Dear support team, The j-link firmware of my nRF52840-DK v3.0.1 is no longer available. Please provide the firmware of nRF5340 so that I can repair the DK.
BR,
zero
I have investigated Zephyr's power managemen API and have the a few questions regarding the nRF52840-DK. The nRF52840-DK was powered externally by the N6705B DC power...
Hi
Does Bosch BME68X_IAQ driver support power management? I can choose between 3 different measurement presets in CONFIG, but I would like to measure values in short ...
Hi, I am using nrf52840dk along with Quectel BG95 module with the sample "cellular modem"
Can i able to use the bg95 driver for nrf52840??
When i tried to build it for...
I am currently investigating the Bluetooth Low Energy (BLE) PHY modes utilized by our nRF52840 device, which lacks documentation and was programmed by an external...
Hello Team Nordic,
Does nRF9160 support Remote Network Driver Interface Specification ( RNDIS)?
The customer ask if nRF9160 supports RNDIS driver due to transfer data...
I'm having problem with SPI devices using nRF Connect SDK 2.6 with a 9160DK. Following lesson 5 in the intermediate course I get BUS FAULTS when the application starts.
I am using nrf52840 and i am working on nrf connect sdk v2.6.0 in my overlay file SPI CS pin is low but it is going high between the communication. Data is not receiving from...
We've developed a custom PCB featuring the nRF52840 Core Chip, but we're encountering significant challenges with antenna performance, resulting in poor range during...
In all the bluetooth samples for the nrf5340, whenever the configuration is set to the cpuapp board, a child image automagically built from the "hci_ipc" sample. What do I...
Today I am attempting to set up an MQTT connection from a Thread device to an MQTT server on the Internet (for better or for worse, if this is a terrible idea I'm open to...
I am looking into relay nodes and my nodes do not seem to relay,
All nodes are provisioned with the same provisioner and have the same keys
The following configs...
We have designed a custom board and just have started testing. We are observing nRF9160 device is rebooting after every 30 seconds. What could be the reason here....
Hi supporter
SDK version:v2.5.2 IDE: VSCODE computer platform:window10 64 bits
I try to connect nRF5340-DK or nRF7002-DK to extenal board(nRF7002 and nRF5340 combo modules...
Hello guys,
i have a problem when trying to add the pairing option on my NUS Bluetooth Peripheral sample.
Zephyr crushs and the board resets when i do accept the pairing...
I'm facing an issue where the whole RAM is filled with 12 bytes repeated.
This issue can happen few minutes or even days after startup. Some of the functions called...
Hi Guys,
I know this question, have been asked many times, but even with the different thread I was not able to solve it..
I'm using LIS2DH sensor with ncs 2.3.0 and...
I would like to implement a simple USB HID Keyboard application on nRF52840 or nRF5340, where a button press on the dev kit sends an HID key over USB. I am using...
I am working on nRF52833 IC for my application and implemented my code on the nRF52833-DK and tested. Now we designed our custom board as per our project requirements...
i have a custom board that uses a nrf5340 that has been hardware modified so i can work again on getting my board to draw the mimimum power from the battery.
i have a PPK2...
Hi all,
I have a SPIS implementation on an nRF52840 running smoothly. Recently I'v had the need to receive large packets (up to 270 bytes) in one single transaction. However...
