SDK: 17.1.0
Chip: NRF52832
IDE: Segger Embedded Studio v5.10d
Developing a bluetooth accessory app for a scale on the NRF52832. Using the ble_nus SDK module.
When...
Hi Nordic team,
I hope this message finds you well. I am currently working on developing applications for custom boards utilizing the nRF Connect SDK v2.4.0, with a particular...
I am trying to build the Serial lTE Modem example from SDK directory C:\ncs\v2.5.1\nrf\applications\serial_lte_modem in VScode then resulting the error:
-- Found...
Hello Nordic Engineer,
I used SDK17.1.0
First chip is examples \ ble_central_and_peripheral \ experimental \ ble_app_multirole_lesc
Second chip is examples \ ble_peripheral...
Hi, i've been trying to use the external flash memory to store new images for OTA firmware update but i keep getting this error
*** Booting nRF Connect SDK v2.5.2 ***...
I am using nrf52840 and SDK -16.0, I wanted to advertise the data when the device is in BLE 5 (LE CODED PHY). Is there is any examples which updates the data during...
I was wondering if there is away to perform DFU using SPI without smp protocol or mcumgr from one nRF52840 to another? What I am trying to do is to send a firmware...
SDK: 17.1.0
Chip: NRF52832
When...
I have a project working on Nora B1, which I am testing on nrf5340DK. It is based on the Peripheral UART Sample, programmed with nfr Connect SDK v1.9.1. Now I need...
Hi Nordic team,
-- Found...
We're using nRF Connect with SDK v2.4.0 (Zephyr). Central and peripheral roles combined.
Custom hardware, with Fanstels module BT840
All was working well, but after extensive...
Good morning!
I hope you will forgive my trivial question but I am a beginner. I don't quite understand the partition structure presented in the "NVS" example. Using the...
I used SDK17.1.0
Hi, We are testing in two cellular service regions, one with LTE-M support and one with NB-IoT support. Following the instructions from this ticket devzone.nordicsemi.com...
we've run into an issue using the SPI master (SPIM). We got the NRF5340 connected to our FPGA using 2 spi busses. The NRF is SPI master on one bus and SPI slave on...
I am currently looking into setting up a Matter project (based on the template) and reached ZAP and the required files. As far as I understood, the ".zap" file is the...
I have the task to integrate MCUboot in a project that will be deployed on a nrf5340. I've enabled MCUboot using KKonfig option `CONFIG_BOOTLOADER_MCUBOOT`. According...
We tested the transmitter and found out that it operates only on 700MHz. Why is that?
The other modems operate on at least four frequencies (800MHz, 1.7Ghz, 1.8Ghz, 1.9Ghz...
Procedures to reproduce this issue are as follows.
1. Unzipping caf_flash.zip to C:\ncs\v2.5.2\nrf\samples folder.
2. cd C:\ncs\v2.5.2\nrf\samples\caf_flash
3. west...
