We are currently developing a WiFi library and just started on implementing HTTPS and ran into some issues. Since we don't have enough flash and memory for using...
I am using a I2C based sensor for my project. I referred to the example projects in the nRF Connect SDK as well as online tutorial for this.
I have 2 questions on the same...
I have been making some board files for our own custom board and was wondering what to set as flash and ram in the
xxx_nrf9160.yaml file and xxx_nrf9160_ns.yaml...
Hello everyone,
I'm presently working on a project that employs the nRF Connect SDK 2.6.0 in a Bluetooth Mesh application. My task involves a requirement to increase the...
I am dealing with a persistent I2S RX overrun issue in the nRF5340 audio application that is impacting data reception and disrupting communications between the gateway...
Hi Support Team,
I'm using nRF5340-DK and the netCore was used for the BLE controller only, the appCore was used for the BLE host and my application.
The below cmake arguments...
I want to program a nRF52840 as RELAY NODE.
If I set CONFIG_BT_MESH_RELAY=n in prj.conf, with nRF Mesh app on my smartphone I see that Relay feature of the node is...
Greetings,
After migrating to the NCS v2.5.2, I noticed a warning that recommends using static partition management (which I have also confirmed is recommended by other...
Hi Team,
Can you please provide your inputs here.
1. Is the nRF9160 SLM supports NIDD(non-ip data delivery)? If yes, can you please provide the AT commands to configure...
I'm trying to develop a Zigbee application for the Seeed Xiao nRF52840 BLE board.
I can compile the "Blinky" demo app in nRF Connect for VS Code and run it on the board...
Is it possible to combine the BLE Uart example with OTA? Our goal is to change the addresses in the filter (BLE Uart central, static ble_gap_addr_t const filter_addr ), by...
Hello my friends,
we have a custom board which includes an nRF52832 being chained to SKY66112-11 FEM. Investigating the radio.c file in the radio-test example, I realized...
I've been working on setting up a direction finding tag with the nrf5340dk. I have an AoA locator set up that advertises with ADV_IND packets, and I'd like to setup my tag...
I am using PCA10056 for external debugging. When I connected PCA10056 to the external NRF52840 module board for debugging and then transferred it to another module,...
I need to update a custom bootloader from the main application running on an nRF52840. The bootloader is contained in 0xF0000 to 0xF90D7 in internal flash, and the S140 SoftDevice...
I'm using a Windows 11 IBM computer. I have gone thru the Dev Academy exercise 1. I installed the software's, nRf for Desktop, nRF Connect SDK, its toolchain, VS Code IDE...
I've stumbled upon an adc_read issue on NRF52832, where following a certain sequence, adc_read gets stuck forever. I'm inserting a small code block that replicates the...
for a development project I need to make a USB device HID. I started from the example project: \v2.6.0\zephyr\samples\subsys\usb\hid so on version 2.6.0 of zephyr...
Is it possible to develope a small iot device 30x30 mm with the setup as described here ?
nRF52805 and nRF9160,
needs to send and receive voice from earbuds, and music...
I a working on a project that uses the nRF5340 CCM peripheral (Network core) in an asynchronous mode. That is, I encrypt PDUs prior to scheduling them for transmission...
I'm using nRF52840 DK with ncs V 2.6.0. I plan to create an mp3 or WAV audio player. I tried using the MAX98357A with the i2s nRF52840 DK board, building a project i2s...
