On a new board based on nRF9160 I am having trouble figuring out how to bring up the board.
I am using Azure IoT hub and can successfully build an application that can connect...
I would like to implement a simple USB HID Keyboard application on nRF52840 or nRF5340, where a button press on the dev kit sends an HID key over USB. I am using...
Hi
I easily got my FW update running using tutorial:
https://academy.nordicsemi.com/courses/nrf-connect-sdk-intermediate/lessons/lesson-8-bootloaders-and-dfu-fota/topic...
I believe that the Nordic fork of hostap ( https://github.com/nrfconnect/sdk-hostap ) has a bug in os.h:
typedef uint64_t os_time_t;
The upstream has that defined as long...
Hi all, i have some problem while i try to estabilish an LTE connection . I'm using nordic n9160dk. I just search through the site, and i see a lot of topic like this , or...
I am using nrf52840 and i am working on nrf connect sdk v2.6.0 in my overlay file SPI CS pin is low but it is going high between the communication. Data is not receiving from...
Hi Guys,
I know this question, have been asked many times, but even with the different thread I was not able to solve it..
I'm using LIS2DH sensor with ncs 2.3.0 and...
I have a custom board using 2 fanstel modules one for the nrf5340 and one for the nrf7002. I am having an issue where about half the boards stop scanning at the exact same...
I've managed to build and flash the project mentioned in this link( devzone.nordicsemi.com/.../459668) to the nrf5340dk with TFM disabled. However, when I attempt to build...
I'm trying to use the Observer example in zephr-sdk-0.16.5 to work with beacons that only use long range coded phy mode. I've updaed prj.conf to take what I believe to be...
I am in the process of making a custom service for a peripheral I am developing. I have some data that I would like to have in the same characteristic because it will be retrieved...
I have new Thingy 53. Default Edge Inpulse demo works without any problem. But I have problem with Weather Station demo.
First I tested Zigbee version. After flashing using...
Hello.
I bought an nRF5340 DK board and am trying to run the HRM example (which uses the ANT+ protocol) on it. The standard (create a new application -> copy a sample) blinky...
I have a custom PCBA with which has the flow of:
- Boot
- Advertise some temperature data read from TWI with a 5 second timeout using `ble_adv_fast_timeout`.
- I then...
I was wondering if there is away to perform DFU using SPI without smp protocol or mcumgr from one nRF52840 to another? What I am trying to do is to send a firmware...
Hi
hi,
1、How can I setting cipher suite version? When I was doing tls bidirectional authentication.
I can't find the AT comand. thanks a lot !
AT #XMQTTCON=<op>[...
Under bootloader/mcuboot/boot/zephyr there is a prj.conf and prj_miminal.conf. By default mcuboot uses the prj.conf. I'd like to know if:
it is possible to configure mcuboot...
We use the nRF52840 hci_usb sample to emulate a mobile phone App communicating with a product, allowing us to check BLE control of a product and data reported back to...
