Hello, I have recently designed a custom board integrated with nrf7002 and nrf52840 qfaa. However, I'm encountering an issue while trying to program the nrf7002 OTP. The RTT...
NCS v2.6.0
nRF52 DK
central_uart send packet to peripheral_uart, then peripheral_uart send write response packet to central_uart.
How to get the write response...
I'm writing an android application, using no.nordicsemi.android:ble:2.3.1. I connect to the sensor and write 49KB data to it. Before recording, I set the desired interval...
Hello everyone,
I have questions. I am trying to scope 32mhz external clock on osilloscope that gwınstek gds-1062 and I show this two picture. First is at 250ms time/div...
1. In ncs v2.6.0 example serial_lte_modem, the level of the P0.26 P0.27 I/O port on the PCA10090 DK board is measurement 0V or 0.8V . Set the high level, normal should...
Hi i am trying to get fw encryption to work for my dfu with mcuboot for nRF9160DK.
I have created a child_image folder with a mcuboot.conf where i have put:
and then...
We want to use a nrf52840 as a logic controller which reads data from Modbus RTU Sensors (as Modbus RTU Master) and simultaneously is the Modbus RTU Server for an...
I'm looking to create a custom board with MDBT50Q-1MV2. Can I directly power it from a LiPo battery (3.7V - 200mAh) only to the VDDH pin? My board is very compact, so I want...
Hello We have nrf5340 min development kits. I am trying to compile the periphal_Ibs example in SDK 2.5.2 and throw it into application and network cores. While I can upload...
I believe that when the nRF5340 operates in LE-Audio CIS mode, the Gateway and Headset are connected, but where is the bonding information set in the source?
Greetings,
After migrating to the NCS v2.5.2, I noticed a warning that recommends using static partition management (which I have also confirmed is recommended by other...
Hi, I am developing an application to read the ADXL355 via SPI. I have not been able to read the register of my accelerometer. And I don't know why. I tried reading the register...
I have a question regarding automating the download process of certificates and software for mass production apllications that need to communicate with an AWS cloud...
I'm facing connectivity issues with my nRF9160DK board,SDK Version: 2.6.0,Modem Firmware Version: 1.3.6.while trying to connect to AWS IoT using the sample code provided...
I got an error while building the direction finding demo In nRF Connect:
../src/main.c:254:10: error: 'const struct bt_conn_cb' has no member named 'cte_report_cb' 254 ...
i have a custom board that uses a nrf5340 that has been hardware modified so i can work again on getting my board to draw the mimimum power from the battery.
i have a PPK2...
Hello, it's a bit urgent, I want it as soon as possible. I made a child image for the MCU boot. my problem is, while compiling code it says the undefined reference to "mcuboot_swap_type...
Hi Nordic
It has not be found much in Nordic documentation about sniffing/monitoring over-the-air communication of Matter.
Any recommendations are appreciated.
Or, would...
NCS v2.6.0
nRF52 DK
I am trying to use a 10-pin flat cable to connect my custom board to nRF52-DK to program the nRF52840 on my custom board.
Just wanted to make sure I connected...
