We have designed a custom board and just have started testing. We are observing nRF9160 device is rebooting after every 30 seconds. What could be the reason here....
Hey I have a question regarding the setup described in the title. I have an application built upon the "Throughput Sample" of Nordic Semiconductor. To get a farther Distance...
I have a custom board using 2 fanstel modules one for the nrf5340 and one for the nrf7002. I am having an issue where about half the boards stop scanning at the exact same...
On a new board based on nRF9160 I am having trouble figuring out how to bring up the board.
I am using Azure IoT hub and can successfully build an application that can connect...
I would like to implement a simple USB HID Keyboard application on nRF52840 or nRF5340, where a button press on the dev kit sends an HID key over USB. I am using...
Hi
I easily got my FW update running using tutorial:
https://academy.nordicsemi.com/courses/nrf-connect-sdk-intermediate/lessons/lesson-8-bootloaders-and-dfu-fota/topic...
I believe that the Nordic fork of hostap ( https://github.com/nrfconnect/sdk-hostap ) has a bug in os.h:
typedef uint64_t os_time_t;
The upstream has that defined as long...
The PPK2 is always on COM4 on my Windows 11 machine, and I can't seem to change it. I bought a 2nd PPK2, and when I plug them both in, they are both on COM4. There is no ...
What are the parameters affecting the Thread network range other than the TX power ?
I am using Micromod nRF52840 module , to test Matter Light Bulb and Matter...
Hello, and thank you for your time. We have designed an NPM1100 into a product, and are unclear on if the behaviour of the charge pin is correct (nor indeed what exactly is...
Under bootloader/mcuboot/boot/zephyr there is a prj.conf and prj_miminal.conf. By default mcuboot uses the prj.conf. I'd like to know if:
it is possible to configure mcuboot...
I have new Thingy 53. Default Edge Inpulse demo works without any problem. But I have problem with Weather Station demo.
First I tested Zigbee version. After flashing using...
Anyone has experience with NCS with ANT+ with FEM? I have a project on nRF5340, NCS 2.4.1, with BLE and ANT+ working... Later on we need to add a FEM to the board, this is...
Request
I need help debugging to figure out why I'm getting the infamous ZEPHYR FATAL ERROR 4: Kernel panic on CPU 0 Any ideas on what I should investigate next would be...
I didn't find any information about the Gain of the Onboard PCB Antenna of the Developement Kit, nor the effective Transmit power that is available. Where can I find it, and...
Hello.
I bought an nRF5340 DK board and am trying to run the HRM example (which uses the ANT+ protocol) on it. The standard (create a new application -> copy a sample) blinky...
I am looking into relay nodes and my nodes do not seem to relay,
All nodes are provisioned with the same provisioner and have the same keys
The following configs...
I've managed to build and flash the project mentioned in this link( devzone.nordicsemi.com/.../459668) to the nrf5340dk with TFM disabled. However, when I attempt to build...
