I've recently designed a custom board that integrates the nrf7002 and nrf52840 qfaa chips. However, I'm encountering an issue while trying to run the scan example on the nRF7002...
I'm using the custom board of nrf 5340 with 7002.
When I run the sample project of Hello World, the current is about 90 ma,
and I run the sample project of WI-FI Scan...
I configured the Gpio 8 as the Rx of UART. When the UART is Idle, I need to configure the G pi o 8 to be an interrupt pin.
This configuration is fine at all times except...
I'm currently working on using a MAX86141 sensor ( datasheet found here ), and I've been running into some issues with communicating with it since this is the first...
We have a project based on nrf5340 audio demo,Now we upgrade SDK from NCS2.4 to NCS2.6.
But when I built the DFU, I found that FLASH was not enough
I know this problem...
I have discovered a bug in the fota_download.c file contained in the SDK. I am attempting to cancel the FOTA update separately within my application code, and it goes...
Hello, I'm trying to use MCUBOOT with external flash on a nRF52840 board that has 4MB SPI flash. I'm using nRF Connect SDK v2.6.0. I've verified that the SPI flash works fine...
I'm implementing flashing modul, which will be running on external mcu. Therefore for the very 1st step, I have captured traffic while performing dfu on PCA10040 via...
Hello folks,
I'm continuing a project that involves porting nRF Desktop ( https://www.nordicsemi.com/Products/Reference-designs/nRF-Desktop ) to the Xiao BLE Sense.
Previously...
in my application (SDK 16.0.0, nRF52840) I perform a DFU and successfully update the application firmware. However I have noticed that from the moment when the DFU...
Hello Nordic Semiconductor Support Team,
We are trying to update application using DFU. We use bootloader, BLE 5 long range coded phy. DFU is not successful, please find...
we are developing custom hard fault handler to get its information during non-debug mode. In order to collect the information in non-debug mode we are trying to store...
We are interested in the NPM1300, but I would like to know the standby or basic current consumption of the buck converters VOUT1 and VOUT2 when there is no load, with...
I'm encountering an issue with the Matter template code in nRF Connect SDK v2.6.0 on my custom board. Strangely, the same code runs perfectly fine on my board when using the...
Hello, I have recently designed a custom board integrated with nrf7002 and nrf52840 qfaa. However, I'm encountering an issue while trying to program the nrf7002 OTP. The RTT...
hello
dear nordic team,im use the nrf5284 develop a keyboard by nrf desktop sdk ,but i dont konw how to chang the ble status in ncs sdk .i hope my keyboard can connect different...
I have noticed while trying to use LitteFS with USB Mass Storage a bug with partition_manager_output.py when using the affiliated key in pm_static.yml. The documentation suggested...
I'm upgrading our application from v2.3.0 to v2.5.0 and I ran into an issue where I can't even get the code to compile any more.
We are using USB mass storage with...
