Hello!
I'm trying to change the output TX power in the nrf5340 audio dk. I'm setting:
CONFIG_BLE_CONN_TX_POWER_NEG_40DBM=y
CONFIG_BLE_ADV_TX_POWER_NEG_40DBM=y
Hi ,
I'm Using nRFconnect SDKV2.3.0 and in the central device i'm jus trying to read RSSI in connnection Callback but it's always reads as 127.
These are my configurations...
In nrf5340 pin assignment for SPIM2 is given,
How to select which pin to use if we need to use SPIM1/3?
How to know Pin function and all its alternate functions...
Hi Everyone,
I am using NRF52833 QFN-40 Package. As I know in datasheet, they have mentioned two I2C Channel is available. I am just curious is for all packages of NRF52833...
I am trying to use PPI / GPIO to measure the 32 kHz clock accuracy for crystal tuning as described in this ticket:
However, the solution points to an example project ( https...
Hello, Karl Ylvisaker. When I use 52840 scan, I sometimes fail to scan other Bluetooth devices for a long time, but the scan will resume after a long time. Other Bluetooth...
I'm implementing flashing modul, which will be running on external mcu. Therefore for the very 1st step, I have captured traffic while performing dfu on PCA10040 via...
So, my issue is weird. Just followed SDK course, installed everything as described, setup, all good, working, updating board etc, couple time freezed but recovered...
I am designing a custom board for nRF52840. I want to use the same antenna that is used in nRF52840 Dongle .
I might be using a different board thickness and...
Hey I have a question regarding the setup described in the title. I have an application built upon the "Throughput Sample" of Nordic Semiconductor. To get a farther Distance...
Hello!
hi
I am developing a product based on the NUS example on nRF52832.
In order to improve the reception sensitivity of the Central Role product, we plan to turn on the...
Starting from the AWS IoT sample, I’m having a hard time configuring the connection before calling net_if_up() which abstracts a lot of stuff. I would like to configure...
I have a custom board and using an external LTE antenna. Please assist me with the configurations to connect to the internet. I once connected with the following but...
Hi
Does Bosch BME68X_IAQ driver support power management? I can choose between 3 different measurement presets in CONFIG, but I would like to measure values in short ...
I have DK of nRF5340, I want to get started with it and create the development env, as well as I need to measure the sleep current for this module?
Any quick tutorial which...
Hello There are multiple tickets regarding this but I could not find the one that specifically handles my case
In my case when MCUboot is enable the flash is overflowed...
I have the logging module activated with two backends UART and RTT. The SHELL module is using UART. I'm trying to control the SHELL UART logging backend at runtime,...
I am currently working on a project involving the nRF5340 Audio Development Kit, and I am facing issues while trying to build the DMIC sample provided in the Zephyr RTOS https...
Hello.
I'm developing some kind of wearable device with using nRF52832.
I'm using Segger Embedded Studio for developing.
I write my code by modifying ble_app_template...
