I a working on a project that uses the nRF5340 CCM peripheral (Network core) in an asynchronous mode. That is, I encrypt PDUs prior to scheduling them for transmission...
Hello.
I'm using a lis2dh in the nrf52840 dev kit and Zephyr on VScode. Using the function sensor_channel_get and the struct sensor_value I need 8 bytes to read each accelerometer...
What is going on here?
I'm trying to get the central_uart example to run on the xiao ble sense nrf52840 board but uart_init() fails when trying to set the callback:
I am writing to seek assistance with an issue I've encountered while attempting to create a modem trace on my nRF9160DK board.
When flashing my asset tracking code...
I'm using nRF52840 DK with ncs V 2.6.0. I plan to create an mp3 or WAV audio player. I tried using the MAX98357A with the i2s nRF52840 DK board, building a project i2s...
Hello, and thank you for your time. We have designed an NPM1100 into a product, and are unclear on if the behaviour of the charge pin is correct (nor indeed what exactly is...
I've a working application on nRF52811 SDK / S140 running BLE. I need to extend it so that from time to time BLE switches off temporarily, to send a simple and short...
In Matter 1.1, I previously encountered the TC-RR-1.1 issue, which was resolved by changing the setting_storage partition size from 16KB to 32KB.
However, in...
I am having a recurring problem with NFC-CONNECT: build action. It hangs when building. Gets stuck with the following message in lower-right hand corner of screen:
The...
I'm using a Windows 11 IBM computer. I have gone thru the Dev Academy exercise 1. I installed the software's, nRf for Desktop, nRF Connect SDK, its toolchain, VS Code IDE...
Hello.
Hi
I have a project base on Nordic sample code "v2.5.0/nrf/samples/cellular/Location" and it fully work with SIM card
now I need to use Onomondo softsim to replace SIM...
Is there any existing support for an e-ink display interfacing with the nRF52840? Something that already has an existing LVGL driver and can be integrated with an nRF...
When I am in BLE_GAP_CONNECTED event, the connection handle is empty? This is log:
[17:54:15.251]input←◆<info> app: Received BLE event: 16 <info> app: Connected. <info>...
Have seen this issue posted before, but none of the fixes worked for me.
This is what I did leading up to the problem:
Opened nRF Connect 3.12
Installed the programmer...
Hello, I am currently working on nrf52840 using nrf-sdk v2.2. to build a Matter firmware. I encountered an issue that a small number of chips UART received data incorrectly...
I programmed an nRF51 devkit for wireshark/nrfsniffing, but now need to restore the original or updated Atmel firmware on nrf51 dev kit for programming BLE chips. Where do...
