Hi all,
I am new to the nordic controllers and ANT+ protocol.
And I am going to evaluate ANT+ protocol in nrf52dk board (nRF52832 controller).
I need to understand which...
I am trying to run the http client on my nrf9160-DK but it is giving me an error below;
*** Booting nRF Connect SDK v2.5.1 *** HTTPS client sample started Bringing...
Hi there,
I'm currently working on the firmware versioning and the downgrade protection for an nRF5340 with NCS 2.6.0.
The firmware consists of:
I currently have...
What is the impact of the power cut off immediately to the chip during boot up or update firmware?
1. Will the power drop immediately to ground?
2. Does the power cut...
Is there any way I can enable Read /write protection from Jtag for NRF BC52805M
I am looking for something like (ST RDP protection level 2) where once we flash...
I am using SDK 2.3.0. I have recently enabled child supervision in a system with one FTD and many SEDs. I am testing backward compatibility with older FTDs which doesn...
Hi all,
Am Implementing Zigbee on NRF52840 chip with help of VS Code.
Zigbee Stack : 2.5.2
I configured nrf52840 DK as Zigbee network coordinator and another custom made...
Hello everyone,
I'm working on a Zigbee project that has the Thingy:53 as an end node. The program of the Thingy is a variation of the Zigbee Weather Station .
I'm measuring...
We're currently working on a project that involves using the NPM1300 to power the NRF52 DK using the GPIO pins. We've managed to supply 3.3V using the GPIO button but...
Hi there,
I currently have...
ble peripheral and central both is nrd52840.softdevice is nrf52.7.2.0. peripheral PHY is 2M ,peripheral send 160K bytes data needs 14 senconds.how to increase the transport...
I am trying to read acceleration values from an acceleration sensor (IIM-42652) via SPI with nrf52832 as the SPI master. I created it based on the spi_pca10040 example,...
Hello!
I'm trying to run an example from the course: Exercise 3 – FOTA over Bluetooth Low Energy . Everything is built without any problems, I use nRF Connect SDK version...
I have the nRF52840 USB dongle, and I want to set up Wirepas by flashing the .hex file. Do I need to set up the nRF5 SDK or Segger EMbedded studio (SES) for this process on...
Hi all , I 'm using NRF52840DK and I want to use RTT to print logging , but I configured a lot of different configs and I can 't print any information in RTT after all . ...
I have developed a USB MIDI application, in which I have deployed USB Device functionality through USB C-type connector. However, when I test the USB virtual COM Port...
Hello All,
I am using nrf52805M from fanstel (LINK) , and code which is based on nrf sdk softdevice S112.
Things works great normally, but in order to satisfy the cyber...
