Hi everyone,
In a project, i am trying to use only channel 38 for extended long range advertising.
Is it possible select only one advertising channel using channel masks...
Hi, I was checking the HAL for SPI in master mode and notice that when pm_device_action_run(<spi_device>, PM_DEVICE_ACTION_SUSPEND); the CS pin isnt changed since it status...
Hi everyone,
I am trying to listing mobile phone using BLE(nrf52833 and software: ble_app_uart_c). I have downloaded nrf connect app on android and then i scanned and...
Due to the increase in functionality, the amount of new application code has increased. After DFU operation, FDS Init failed to restart. However, if I use the complete hexadecimal...
Hi, I try to connect ble devices to my iphone. I can send hid data over bluetooth but virtual keypad is hiding. I cant open it. I tried to send 0x65 data as hid report but...
I am using the nRF9160 aws_iot sample. I was now trying somethings that are not optimal situations.
For example, I made some FIFO buffer to write in measurements in one...
Hello!
I have a device on which the S25HL01GT memory is soldered. The problem is that I don’t understand how I should work with .dts in order for this memory to work with...
Hello my friends,
we have a custom board which includes an nRF52832 being chained to SKY66112-11 FEM. Investigating the radio.c file in the radio-test example, I realized...
Hello, we have a product that uses the NRF52832. We recently detected that the device will randomly increase its current consumption by about 260uA during sleep mode. Once...
Hi everyone,
I am currently researching the capabilities of Bluetooth Mesh with the nRF5340 DK. I have two DK's which are communicating over Mesh where one sends data (20 bytes) to the...
i can't open example blinky for pca1056 in Keil C 5 in sdk _17.1.0
i have installed all package about Nordic but it isn't worked.
Beside, Can i flash code to nrf52840...
I a working on a project that uses the nRF5340 CCM peripheral (Network core) in an asynchronous mode. That is, I encrypt PDUs prior to scheduling them for transmission...
I'm facing an issue where the whole RAM is filled with 12 bytes repeated.
This issue can happen few minutes or even days after startup. Some of the functions called...
Hi everyone,
1. am currently using the nrf9161_dk. and have not modified the modem FW in anyway.
2. I am using the vscode extension provided by nordic to build/run this sample
a, i...
For reasons beyond my control I need to do some changes to a nrf9160 project that was developed using nrfConnect v1.2.1. I know the ideal situation is to upgrade it to the...
I'm looking to create a custom board with MDBT50Q-1MV2. Can I directly power it from a LiPo battery (3.7V - 200mAh) only to the VDDH pin? My board is very compact, so I want...
I want to program a nRF52840 as RELAY NODE.
If I set CONFIG_BT_MESH_RELAY=n in prj.conf, with nRF Mesh app on my smartphone I see that Relay feature of the node is...
I am using the latest version (v4.0.4) of the app Bluetooth Low Energy when I select the device the page loads for about 1s and then the page gets white again. I also tried...
