In nrf5340 pin assignment for SPIM2 is given,
How to select which pin to use if we need to use SPIM1/3?
How to know Pin function and all its alternate functions...
Dear Support team,
Project information :
Hardware : nRF5340 Custom Board
SDK : nRF Connect SDK v2.2.0
I have integrated watchdog timer to my project. I've used...
Hi Everyone,
I am using NRF52833 QFN-40 Package. As I know in datasheet, they have mentioned two I2C Channel is available. I am just curious is for all packages of NRF52833...
I am trying to use PPI / GPIO to measure the 32 kHz clock accuracy for crystal tuning as described in this ticket:
However, the solution points to an example project ( https...
Hello, Karl Ylvisaker. When I use 52840 scan, I sometimes fail to scan other Bluetooth devices for a long time, but the scan will resume after a long time. Other Bluetooth...
hi
I am developing using nRF52832 and SDK 17.0.1 (NUS).
I configured paring using BLE Name filter...
I can't find the part that modifies the central response...
Dear Nordic Support
Recently I have the issue that the nrf-connect.toolchain.path, set in the VS-Code workspace file, doesn't correctly resolve if predefined VS-Code variables...
The PPK2 is always on COM4 on my Windows 11 machine, and I can't seem to change it. I bought a 2nd PPK2, and when I plug them both in, they are both on COM4. There is no ...
I think, I found a missing configuration in the QSPI driver for the nrf53 in nrfx_qspi.c. I've stumbled off this, while I was trying to configure MCUboot for the external...
Dear Support team,
I am using PCA10056 for external debugging. When I connected PCA10056 to the external NRF52840 module board for debugging and then transferred it to another module,...
Hi Everyone,
I tried implementing a PDM interface for recording sound from a microphone on the nrf52840. For this purpose, I used the official example which is accessible at github.com...
Hello Nordic support, I work on receive data from the microphone mp34dt05-a . I have some question. 1- How to enable PDM in SDK_CONFIG.H . 2- For this project do I need enable...
Hi Nordic,
I am exploring on how to use an ADC module for measuring the battery percentage for my nrf52840. I am working on the nrf connect SDK. Can anyone suggest me a...
I'm attempting to generate a binary blob containing both the S140 SoftDevice (to be placed at address 0x1000 in flash) and the main application firmware (at 0x26000).
I...
hi,I am using the NRF52840, softdevice: s140,
If a Bluetooth host simultaneously connects to multiple Bluetooth peripherals, and the peripherals transmit data to the host...
hello,
I made a development board using the nrf52840 module.
What methods are there to measure power consumption?
I know of two methods: measuring with the Power Profiler...
Hello!
I have a device on which the S25HL01GT memory is soldered. The problem is that I don’t understand how I should work with .dts in order for this memory to work with...
