Hello Team,
I have been using a NRF52840DK to program external boards. Recently it started misbehaving and will not detect external boards connected to it. I would like...
Hi all,
I am trying to flash the nRF 5340 Audio DK boards with the nRF5240_audio sample. When using the buildprog.py script to flash my three boards, the script fails due...
Using the official nRF Connect for VS Code extension sometimes when debugging and hitting a fatal error, no backtrace is shown (backtrace seems to be mostly garbage):
Hello, I am trying to communicate with a Bosch BMI 270 device( datasheet ) using the nrf5340dk. I macgyvered something together from the bmi270 file in the zephyr/sensor folder...
Hi all,
I am new to the nordic controllers and ANT+ protocol.
And I am going to evaluate ANT+ protocol in nrf52dk board (nRF52832 controller).
I need to understand which...
Hi, I recently installed the last version of the SDK v2.5.2 and when I try to build the sample direction_finding_central I am getting the following error
I am running...
I am trying to read acceleration values from an acceleration sensor (IIM-42652) via SPI with nrf52832 as the SPI master. I created it based on the spi_pca10040 example,...
Hi there!
I am trying to make an application that plays an audio sample to a BLE speaker (another nRF5340 running as headset) where the audio sample is in memory. I have...
Hi all , I 'm using NRF52840DK and I want to use RTT to print logging , but I configured a lot of different configs and I can 't print any information in RTT after all . ...
We are developing a custom board having nrf9160 cellular modem and we are using serial ltm application in it.
in serial ltm application there is pin selection...
Hi
I am working on a high throughput application.
I use this function to send the notifications: bt_gatt_notify_cb()
Am I right that this function has an internal queue...
I am attempting to work thru the tutorial exactly per the instructions, and I'm stuck in Lesson 1 at
6. Wait for the device to connect to nRF Cloud.
The Cellular Monitor...
Hello Team,
Hello everyone,
I'm working on a Zigbee project that has the Thingy:53 as an end node. The program of the Thingy is a variation of the Zigbee Weather Station .
I'm measuring...
Hi there,
Zephyr has ability for an Application version management . Based on this, I have created a "Version" file, without any file name extension (like .txt).
Now...
When building with nordic sdk 2.6 and zephyr 3.5 we get the following cmake warnings. How should they be interpreted?
CMake Warning: Manually-specified variables were not...
Hi all,
I am trying to drive my OLED by nrf52833DK.
The OLED is offered by online shop that with a description that SSD1306.
I don't know whether the drive is offered in zephyr...
Hi Team,
I have 1 nRF5340 Audio DK. With the steps mentioned in below links, I configured Json file to Headset and I'm able to achieve it. ( developer.nordicsemi.com/.....
