Hi,I'm develop with the nRF52840 V17.0.2 ,SD 7.2.0
problem about migrate LVGL 8.1
I have few app_timer ,they are work fine
try to migrate LVGL
alfter lv_init(), app_timer...
I am try to connect AWS IoT MQTT using nRF7002DK. I followed the below link.
https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/libraries/networking/aws_iot...
We are evaluating a pedal power meter for bicycle, but have a question we would like some advice.
Usually pedal-type power meters are divided into left and right sides...
Hello DevZone,
I'm trying to run Matter over Thread demo on nRF7002DK. In fact, it's not a real 7002DK, but a simplified version. You can check the documents about this...
Hello, support team:
Environment describe: nrf52840,NCS v2.4.0;
I am developint on nrf52840 with openthread.One of the device is thread Leader and others as thread EndDevice...
I am using the I2S slave mode in my nrf52840 based board (seeed studio xiao), I am confused regarding the I2S interface. I actually opened another ticket but nobody seems...
I am using nRF52832 board and I want to understand the current consumption in the board will differs while running the code in zephyr RTOS platform and without zephyr...
I added CONFIG_PM_EXTERNAL_FLASH_MCUBOOT_SECONDARY=y to prj.conf file. And adding the following content to pm_static_dfu.yml file. But west build failed.
The following...
try to migrate LVGL
I copied from pm_static.yml from C:\ncs\v2.5.2\nrf\applications\nrf_desktop\configuration\nrf5340dk_nrf5340_cpuapp\pm_static.yml. And adding the following setting in CMakeLists...
After considerable investigation, it seems that using the nRF5340 + nRF7002 combo with some realistic WiFi client comms enabled (eg. using MQTT) results in an image that's...
Hi Nordic
I had used pynrfjprog to update modem of nrf9160 for a long time. Everything ran well and smoothly.
But, yesterday, I found it failed to update modem. I have...
currently I am working on a private project where I need a small OLED Display. Therefore I bought a 0.96" OLED Display (128x64) with a SSD1306 IC Driver on it.
First...
I am currently looking into setting up a Matter project (based on the template) and reached ZAP and the required files. As far as I understood, the ".zap" file is the...
Hello DevZone,
I am currently evaluating the new feature called Periodic Advertising with Responses (PAwR) using Nordic's Softdevice controller.
Below you find project related...
product details:
nRF52840 custom board
nRFConnectSDK 2.2.0
we want to implement custom service interacting with the Android app.
Where we will receive on command from...
Procedures to reproduce this issue are as follows.
1. Unzipping caf_flash.zip to C:\ncs\v2.5.2\nrf\samples folder.
2. cd C:\ncs\v2.5.2\nrf\samples\caf_flash
3. west...
Just upgraded to NRF v 2.6.0 (Mac OS; VS Code). Our code previous built and ran successfully on our custom board with v 2.5.0 of the SDK.
Now we get the following error...
