Hi i am trying to get fw encryption to work for my dfu with mcuboot for nRF9160DK.
I have created a child_image folder with a mcuboot.conf where i have put:
and then...
I have a question regarding automating the download process of certificates and software for mass production apllications that need to communicate with an AWS cloud...
We want to use a nrf52840 as a logic controller which reads data from Modbus RTU Sensors (as Modbus RTU Master) and simultaneously is the Modbus RTU Server for an...
Is it possible to combine the BLE Uart example with OTA? Our goal is to change the addresses in the filter (BLE Uart central, static ble_gap_addr_t const filter_addr ), by...
Hello We have nrf5340 min development kits. I am trying to compile the periphal_Ibs example in SDK 2.5.2 and throw it into application and network cores. While I can upload...
I'm encountering an issue with the Matter template code in nRF Connect SDK v2.6.0 on my custom board. Strangely, the same code runs perfectly fine on my board when using the...
I've stumbled upon an adc_read issue on NRF52832, where following a certain sequence, adc_read gets stuck forever. I'm inserting a small code block that replicates the...
Features
nRF52840
nRF52832
System current consumption DC/DC at 3 V
0.5μA at 3V System OFF mode,
no RAM retention
1.5μA System ON mode, no RAM retention...
and then...
Hi guys!
Right now I have my custom board which used nRF52833 SoC. There is only one reset button on custom board and dfu performed via uart.
I flashed four hex file ...
Hi.
I want to modify the "nPM1300 One Button" example.
I need the Ship mode to be activated after pressing and holding the SHPHLD button for longer than 3 seconds. The...
HI,
two years ago I started my adventure with the nRF52840 microcontroller. I started using SEGGER Embedded Studio for ARM as my development IDE. I created a peripheral...
Good Day!
Can you please tell me if nRF52 microcontrollers are well suited for creating a cold cryptocurrency wallet based on them?
Do you have libraries, APIs or any...
I would like to test Pulse Width Modulation (PWM) on nRF52832 DK. But west build failed with the following messages.
C:\ncs\v2.5.2\nrf\samples\pwm_52832>west build -b nrf52dk_nrf52832...
Hello, I'm trying to use MCUBOOT with external flash on a nRF52840 board that has 4MB SPI flash. I'm using nRF Connect SDK v2.6.0. I've verified that the SPI flash works fine...
We have been using SDK version 2.1.1 and currently are in the process of migrating to SDK version 2.5.0.
Would be helpful to get some hint regarding what conditions...
NRF_ERROR_FORBIDDEN
Forbidden value supplied, certain UUIDs are reserved for the stack.
I was developing a new sw in demo board. I have added some new services and...
Hi, I'm having trouble finding out which update caused my application to crash. The build works fine with nRF Connect 2.43, but with the latest version (2.6), it doesn't work...
