Dear support team, The j-link firmware of my nRF52840-DK v3.0.1 is no longer available. Please provide the firmware of nRF5340 so that I can repair the DK.
BR,
zero
I have investigated Zephyr's power managemen API and have the a few questions regarding the nRF52840-DK. The nRF52840-DK was powered externally by the N6705B DC power...
I have a SIM card that connects via MQTT from an nrf9160 to a server. (using mqtt sample)
The cell search is slow, but once it connects (after a long time), it stays...
I connected one external BH1749 sensor with nrf5340DK and was testing it with the bh1749 sample code but the sensor is only getting initialized and I am getting [00:00:00...
Hi
Does Bosch BME68X_IAQ driver support power management? I can choose between 3 different measurement presets in CONFIG, but I would like to measure values in short ...
Hi, I am using nrf52840dk along with Quectel BG95 module with the sample "cellular modem"
Can i able to use the bg95 driver for nrf52840??
When i tried to build it for...
I am currently investigating the Bluetooth Low Energy (BLE) PHY modes utilized by our nRF52840 device, which lacks documentation and was programmed by an external...
Hi Nordic,
I am exploring on how to use an ADC module for measuring the battery percentage for my nrf52840. I am working on the nrf connect SDK. Can anyone suggest me a...
Hi
I struggle with my external QSPI flash and power consumption of our custom board (at least I think that would be the problem with too high idle power consumption)....
Greetings
I am trying to measure the current consumption of my board (does not use a Nordic SoC), and the power profiler in unison with the NrfConnect SDK app measures current...
Is there a call back for config server for ble mesh?
Lets say, when relay mode is set, I can bring that out in a callback to do something?
if a key is bound to...
hey! So i require some guidance regarding the implementation of system ON low power mode in my sdk. 1. I have configured interrupts for all button press, so that the interrupt...
I have a lis3dh sensor where I want to configure the interrupts. I am currently struggling to extract the information from the irq-gpios phandle to the c driver. I went through...
I've been following the steps indicated by the " nRF_Sniffer_BLE_UG_v4.1.x" document in order to set up my nRF52840 dongle as a BLE sniffer for Wireshark. Unfortunately...
Hey I have a question regarding the setup described in the title. I have an application built upon the "Throughput Sample" of Nordic Semiconductor. To get a farther Distance...
I am looking into relay nodes and my nodes do not seem to relay,
All nodes are provisioned with the same provisioner and have the same keys
The following configs...
I'm currently working on using a MAX86141 sensor ( datasheet found here ), and I've been running into some issues with communicating with it since this is the first...
We recently got the NRF9151-DK and were trting to measure the e-DRX current on the system working on CAT-M1 network. The NRF9151 DK is loaded with Serial LTE Modem application...
Hi
I am stuck using a proximus M2M sim card with the AWS-IoT sample. I did get it working with an Ibasis sim card but now I want to use a Proximus M2M sim card but I keep...
On a new board based on nRF9160 I am having trouble figuring out how to bring up the board.
I am using Azure IoT hub and can successfully build an application that can connect...
