1. In ncs v2.6.0 example serial_lte_modem, the level of the P0.26 P0.27 I/O port on the PCA10090 DK board is measurement 0V or 0.8V . Set the high level, normal should...
I am trying to use a 10-pin flat cable to connect my custom board to nRF52-DK to program the nRF52840 on my custom board.
Just wanted to make sure I connected...
Hi i am trying to get fw encryption to work for my dfu with mcuboot for nRF9160DK.
I have created a child_image folder with a mcuboot.conf where i have put:
and then...
I have a question regarding automating the download process of certificates and software for mass production apllications that need to communicate with an AWS cloud...
We want to use a nrf52840 as a logic controller which reads data from Modbus RTU Sensors (as Modbus RTU Master) and simultaneously is the Modbus RTU Server for an...
Is it possible to combine the BLE Uart example with OTA? Our goal is to change the addresses in the filter (BLE Uart central, static ble_gap_addr_t const filter_addr ), by...
Hello We have nrf5340 min development kits. I am trying to compile the periphal_Ibs example in SDK 2.5.2 and throw it into application and network cores. While I can upload...
OS: Ubuntu 20.04.6 NCS SDK: 1.6.1 Segger: 5.50c
I recently got a new laptop, which I installed using the following guide:
https://developer.nordicsemi.com/nRF_Connect_SDK...
Power-on reset will require pairing again.
I found this happening by doing bt_id_reset().
Is there a problem with the way the BD address is initialized?
How to initialize...
Good Day!
Can you please tell me if nRF52 microcontrollers are well suited for creating a cold cryptocurrency wallet based on them?
Do you have libraries, APIs or any...
Hi guys:
Right now I have my custom board using nRF52833.
I wang to use DFU over uart to upgrade firmware.
I try a different way to enter DFU mode, and this require...
There was no problem when using the circuit below in the previous circuit,
After removing the USB part and changing the circuit as shown above, the input is that the CHG...
Hi there,
I have a custom board featuring the nRF52840. This is the relevant part of the schematic.
When pressing SW1, the SoC doesn't get reset. Seemingly, it's as...
I've stumbled upon an adc_read issue on NRF52832, where following a certain sequence, adc_read gets stuck forever. I'm inserting a small code block that replicates the...
Hi there
I've been using Nordic nRF Connect SDK v2.4.1 for my Matter application development. I've been working on features to report Matter network status correctly and...
Hi supporter
I use the sample "interfacing with a sensor over SPI"( academy.nordicsemi.com/.../) , modified as BMP280 and ST-lis2hh12 sensor.I use vscode build environment...
I have a project on a custom board with Nrf5340 coming up which is using a lot og GPIO's
Doing some tests on the nrf5340 I saw I cannot use some gpios because they...
I have developed a USB MIDI application, in which I have deployed USB Device functionality through USB C-type connector. However, when I test the USB virtual COM Port...
Hi, i wanted to add OTA DFU to an MQTT application i coded using zephyr APIs on my nrf52840DK with nrf7002ek.
The problem is that MQTT takes already a lot of RAM and flash...
The Central device is using Resolvable Private Addresses.
Even though private_addr_cycle_s is set to BLE_GAP_DEFAULT_PRIVATE_ADDR_CYCLE_INTERVAL_S (15 minutes),
When observed...
