I am using a PCA10056 Dev Kit to test the accel sensor(IIS3DWB). But the SPI transfer is stuck at the line below.
Here is more information.
1.ST provided an official...
1. am currently using the nrf9161_dk. and have not modified the modem FW in anyway.
2. I am using the vscode extension provided by nordic to build/run this sample
a, i...
I've followed the reference circuitry pretty explicitly ( here ), however, I want to confirm that this configuration will give me DCDCEN1 capability for power supply consumption...
Hello, there seem to be a lot of technical details missing from the datasheet. In my case, I really need to know the capabilities of the load switches such as reverse current...
i have a custom board that uses a nrf5340 that has been hardware modified so i can work again on getting my board to draw the mimimum power from the battery.
i have a PPK2...
I have a custom PCBA with which has the flow of:
- Boot
- Advertise some temperature data read from TWI with a 5 second timeout using `ble_adv_fast_timeout`.
- I then...
I've been working on setting up a direction finding tag with the nrf5340dk. I have an AoA locator set up that advertises with ADV_IND packets, and I'd like to setup my tag...
I'm using a Windows 11 IBM computer. I have gone thru the Dev Academy exercise 1. I installed the software's, nRf for Desktop, nRF Connect SDK, its toolchain, VS Code IDE...
Hi, I need help with these tasks in Lesson 2 ex 2 (step 7. and 8.)
Looking for that path and python file everywhere, unable to find it, I don't have zephyr folder, none...
a, i...
There was no problem when using the circuit below in the previous circuit,
After removing the USB part and changing the circuit as shown above, the input is that the CHG...
I seem to remember information on the scalability of the nRF Cloud, but I cannot locate it anymore. Where would I find such documentation?
Thanks, -- Terrence
i have a PPK2...
I am recently trying to get up and running with the nrf9160-DK and have been unable to flash the board successfully even with the Quick start (v0.2.6) app in nrf Connect....
- Boot
- I then...
I a working on a project that uses the nRF5340 CCM peripheral (Network core) in an asynchronous mode. That is, I encrypt PDUs prior to scheduling them for transmission...
In Matter 1.1, I previously encountered the TC-RR-1.1 issue, which was resolved by changing the setting_storage partition size from 16KB to 32KB.
However, in...
I am having a recurring problem with NFC-CONNECT: build action. It hangs when building. Gets stuck with the following message in lower-right hand corner of screen:
The...
