I have investigated Zephyr's power managemen API and have the a few questions regarding the nRF52840-DK. The nRF52840-DK was powered externally by the N6705B DC power...
I have a SIM card that connects via MQTT from an nrf9160 to a server. (using mqtt sample)
The cell search is slow, but once it connects (after a long time), it stays...
I erase and flash nrf52840 dongle with nrf connect, then I read the value or REGOUT0 and the result is 0xFFFFFFFC that corresponds to Vout = 3V.
I'd like to know in...
I connected one external BH1749 sensor with nrf5340DK and was testing it with the bh1749 sample code but the sensor is only getting initialized and I am getting [00:00:00...
Hi
Does Bosch BME68X_IAQ driver support power management? I can choose between 3 different measurement presets in CONFIG, but I would like to measure values in short ...
Hi, I am using nrf52840dk along with Quectel BG95 module with the sample "cellular modem"
Can i able to use the bg95 driver for nrf52840??
When i tried to build it for...
I am currently investigating the Bluetooth Low Energy (BLE) PHY modes utilized by our nRF52840 device, which lacks documentation and was programmed by an external...
Hi, I try to connect ble devices to my iphone. I can send hid data over bluetooth but virtual keypad is hiding. I cant open it. I tried to send 0x65 data as hid report but...
Greetings
I am trying to measure the current consumption of my board (does not use a Nordic SoC), and the power profiler in unison with the NrfConnect SDK app measures current...
I have the nRF52840 USB dongle, and I want to set up Wirepas by flashing the .hex file. Do I need to set up the nRF5 SDK or Segger EMbedded studio (SES) for this process on...
Hi
I'm trying to build Matter: Template app for nrf5340dk_nrf5340_cpuapp but I get this error:
The application configuration file is: prj.conf
While I can build...
Is it possible to flash the application onto the nRF52840 USB dongle using this method?
https://developer.wirepas.com/support/solutions/articles/77000465762-how-to-flash...
For reasons beyond my control I need to do some changes to a nrf9160 project that was developed using nrfConnect v1.2.1. I know the ideal situation is to upgrade it to the...
I am in the process of making a custom service for a peripheral I am developing. I have some data that I would like to have in the same characteristic because it will be retrieved...
We have a project based on nrf5340 audio demo,Now we upgrade SDK from NCS2.4 to NCS2.6.
But when I built the DFU, I found that FLASH was not enough
I know this problem...
https://devzone.nordicsemi.com/f/nordic-q-a/44658/communication-probl
I want to change the code provided in this link to enter the password from the peripheral
I have a custom PCBA with which has the flow of:
- Boot
- Advertise some temperature data read from TWI with a 5 second timeout using `ble_adv_fast_timeout`.
- I then...
Hello, I am trying to get the asset tracker v2 working on the DEV board nRF9151-DK.
I have got the asset tracker v2 to compile , and also started the process with the at_client...
Hi, we are looking to build a bluetooth speaker(Product Prototype) where the mcu using I2S it communicates to the amplifier IC(TAS5806) from TI, Can we use nrf52840 for this...
