I have the logging module activated with two backends UART and RTT. The SHELL module is using UART. I'm trying to control the SHELL UART logging backend at runtime,...
We are developing for the NRF5340 and Zephyr (SDK 2.5.0). As we approach the first preproduction run, we are realizing we need a better way to set device names than...
I'm testing the IQ feature of the radio test. According to the documentation on https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/samples/wifi/radio_test...
Hi all,
I have a SPIS implementation on an nRF52840 running smoothly. Recently I'v had the need to receive large packets (up to 270 bytes) in one single transaction. However...
We've developed a custom PCB featuring the nRF52840 Core Chip, but we're encountering significant challenges with antenna performance, resulting in poor range during...
I want to read data from 8 channels of ADC, when configuring all channels it shows that some of the pins are pre-occupied by other nodes. i have applied different things to...
We have designed a custom board and just have started testing. We are observing nRF9160 device is rebooting after every 30 seconds. What could be the reason here....
I'm experiencing an intermittent problem where nRF9160 devices aren't able to establish an LTE connection. Recently our SIM provider made a configuration change that...
Hi there
I'm working on nRF5340 chip and looking for a way to preserve the factory data that is saved in factory_data region. I tried playing around with the factory data...
Hello, I'm trying to provision nRF9160 DK in nRF Cloud using https://docs.nordicsemi.com/bundle/nrf-cloud/page/SecurityServices/ProvisioningService/ProvisioningOverview.html...
Hi there!
I am trying to make an application that plays an audio sample to a BLE speaker (another nRF5340 running as headset) where the audio sample is in memory. I have...
What are the parameters affecting the Thread network range other than the TX power ?
I am using Micromod nRF52840 module , to test Matter Light Bulb and Matter...
We have a BLE, battery powered device where we'd like to enter low power modes whenever possible by dynamically switching between HFXO and HFINT such that our application...
Under bootloader/mcuboot/boot/zephyr there is a prj.conf and prj_miminal.conf. By default mcuboot uses the prj.conf. I'd like to know if:
it is possible to configure mcuboot...
I am reaching out regarding some challenges I've encountered with SPI communication on the nRF7002DK when interfacing with the ETH Wiz Click | Mikroe module and a...
We need to do some crypto. The first task being to generate a random number with rng. I have been fighting through the sdk_config.h defines, and the list of modules that need...
Hi Support Team,
I want to use an external flash(2M byte) to store the sensor data in a 'circular overwrite' way. I now tried it with the FCB(Flash Circular Buffer) on nRF5340...
Hi there,
I'm looking for documentation regarding the DECT NR+ software stack / SDK available for nRF9161. I noticed on other threads that not much was available. My interest...
Hi all,
