I am using nrf52840 and SDK -16.0, I wanted to advertise the data when the device is in BLE 5 (LE CODED PHY). Is there is any examples which updates the data during...
I have ported my 2.5.2 project to 2.6.0 - its not 100% functional but that i because the buttons events are handled slightly differently. Anyways, there is this structure...
Is there any mechanism to identify device relationship (parent , child relationship).
Do nRF Mesh maintain any topology?
Thanks in advance.
Robert...
Hi all,
I am designing a wearable device with a strap (concept as attached image)
I plan to design the RF antenna on the flex PCB and then place it inside the strap (strap...
example:ble_app_uart + secure_bootloader sdk:17.1 hello. Well, a strange phenomenon occurred when I was testing the connection between our ble device and the app。 Our app...
hi support team,
how to use flash partial operation for nrf sdk 17.1 and soc 52840? i have tried below code, but it still stop usb to receive data from pc very quicky, for...
I am currently looking into setting up a Matter project (based on the template) and reached ZAP and the required files. As far as I understood, the ".zap" file is the...
I have the task to integrate MCUboot in a project that will be deployed on a nrf5340. I've enabled MCUboot using KKonfig option `CONFIG_BOOTLOADER_MCUBOOT`. According...
We tested the transmitter and found out that it operates only on 700MHz. Why is that?
The other modems operate on at least four frequencies (800MHz, 1.7Ghz, 1.8Ghz, 1.9Ghz...
Procedures to reproduce this issue are as follows.
1. Unzipping caf_flash.zip to C:\ncs\v2.5.2\nrf\samples folder.
2. cd C:\ncs\v2.5.2\nrf\samples\caf_flash
3. west...
Hi, I am currently working with the nRF9160DK board, using SDK version 2.5.1, and I have encountered an issue regarding connectivity to the AWS IoT cloud.
I have successfully...
I'm trying to merge together a couple of sample projects to make a prototype (in particular, the LTE-BLE gateway, and AWS-IoT samples) - to run on the nRF 9160DK...
I'm using an nrf52833 with SDK 17.1.0 and was looking at the peripheral/libuarte example. I have a question regarding the following code snippet
Can someone explain...
The welcome page
for nRF connect extention pack does not appear anymore.So not able to compile and run programs.
Also noticed that the compilation works with...
Hi supporter
Iuse two DK boards for nRF7002-DK & nRF5340-DK, SDK version is V2.5.2, sample code nrfx_spim_spis_nonblocking in C:\ncs\v2.5.2\modules\hal\nordic\nrfx\samples...
Good evening,
I am working on a project using a customized board with nrf52840. The project is built on MBed. I am trying to switch to nRF Connect SDK. The first step is...
I am building and testing the nRF5340 audio application from the latest SDK 2.6.0 and trying to get FOTA updates working by following this guide :
https://developer.nordicsemi...
I have completed a project based on nrf52840 as a peripheral device.
These days, i am expirementing with nrf52840 as a central device. I have successfully scanned...
