Hi! I'm currently developing a project that uses mcuboot. For some evaluation purposes, I'm testing stuff on nrf5480dk and today I came across a strange error. After flashing...
I am reaching out regarding some challenges I've encountered with SPI communication on the nRF7002DK when interfacing with the ETH Wiz Click | Mikroe module and a...
We are currently developing a WiFi library and just started on implementing HTTPS and ran into some issues. Since we don't have enough flash and memory for using...
I am using a I2C based sensor for my project. I referred to the example projects in the nRF Connect SDK as well as online tutorial for this.
I have 2 questions on the same...
I have been making some board files for our own custom board and was wondering what to set as flash and ram in the
xxx_nrf9160.yaml file and xxx_nrf9160_ns.yaml...
Hello everyone,
I'm presently working on a project that employs the nRF Connect SDK 2.6.0 in a Bluetooth Mesh application. My task involves a requirement to increase the...
I've managed to build and flash the project mentioned in this link( devzone.nordicsemi.com/.../459668) to the nrf5340dk with TFM disabled. However, when I attempt to build...
Hello, I am trying to get the latest hello or dut samples to work for sidewalk in the 2.6.0 release but I am running into an issue with a panic when booting. I have had sidewalk...
Accidentally used a 9V power supply. Board does not flash anymore.
Can still connect to com ports, and onboard led lights up.
Is the board fried or is it stuck in a memory...
Hello my friends,
we have a custom board which includes an nRF52832 being chained to SKY66112-11 FEM. Investigating the radio.c file in the radio-test example, I realized...
Using the Zephyr how can I set a TWI module clock frequency different from the standard speeds?
With nRF SDK I was able to do this by setting "frequency = 0x00290000UL...
Hi, I need help with these tasks in Lesson 2 ex 2 (step 7. and 8.)
Looking for that path and python file everywhere, unable to find it, I don't have zephyr folder, none...
Hi
I am trying to establish a ble oob pairing in legacy mode to meet security level 3.
Therefore i am using the example project peripheral_nfc_pairing and the nRF...
I've followed the reference circuitry pretty explicitly ( here ), however, I want to confirm that this configuration will give me DCDCEN1 capability for power supply consumption...
Greetings,
After migrating to the NCS v2.5.2, I noticed a warning that recommends using static partition management (which I have also confirmed is recommended by other...
Hi Team,
Can you please provide your inputs here.
1. Is the nRF9160 SLM supports NIDD(non-ip data delivery)? If yes, can you please provide the AT commands to configure...
I'm trying to develop a Zigbee application for the Seeed Xiao nRF52840 BLE board.
I can compile the "Blinky" demo app in nRF Connect for VS Code and run it on the board...
Is it possible to combine the BLE Uart example with OTA? Our goal is to change the addresses in the filter (BLE Uart central, static ble_gap_addr_t const filter_addr ), by...
