I've been trying to get MCUboot to work with Direct XIP for several days but each time I have a compilation problem:
In fact, I would like to have a project...
Hi,I'm develop with the nRF52840 V17.0.2 ,SD 7.2.0
problem about migrate LVGL 8.1
I have few app_timer ,they are work fine
try to migrate LVGL
alfter lv_init(), app_timer...
I am try to connect AWS IoT MQTT using nRF7002DK. I followed the below link.
https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/libraries/networking/aws_iot...
Hello DevZone,
I'm trying to run Matter over Thread demo on nRF7002DK. In fact, it's not a real 7002DK, but a simplified version. You can check the documents about this...
Hello, support team:
Environment describe: nrf52840,NCS v2.4.0;
I am developint on nrf52840 with openthread.One of the device is thread Leader and others as thread EndDevice...
I am using the I2S slave mode in my nrf52840 based board (seeed studio xiao), I am confused regarding the I2S interface. I actually opened another ticket but nobody seems...
I would like to put mcuboot in external NOR flash storage for saving internal nRF5340 flash storage. Does Nordic provide sample code for putting mcuboot in external NOR flash...
ncs 2.6.0
I'm encountering a weird bus data error when I'm calling psa_generate_random inside a work queue thread (it has name "api"):
The code I'm running...
I built the littlefs zephyr example found in "/zephyr/samples/subsys/fs/littlefs"and then modified it to use the external flash "MX25R64" by adding an app.overlay file. I...
We are evaluating a pedal power meter for bicycle, but have a question we would like some advice.
Usually pedal-type power meters are divided into left and right sides...
I am using nRF52832 board and I want to understand the current consumption in the board will differs while running the code in zephyr RTOS platform and without zephyr...
I'm on a research to find out how I can use synchronization feature only from LTE for other Wireless Sensor Network.
In online profiler page, There's no explanation about...
Hi, I am currently working with the nRF9160DK board, using SDK version 2.5.1, and I have encountered an issue regarding connectivity to the AWS IoT cloud.
I have successfully...
Hi, i've been trying to use the external flash memory to store new images for OTA firmware update but i keep getting this error
*** Booting nRF Connect SDK v2.5.2 ***...
Hi Team,
I'm using nrf9160. I'm trying to connect to the network by using the nrf9160 controller with in built modem. I'm getting the error code -14 and modem not initialized...
I added CONFIG_PM_EXTERNAL_FLASH_MCUBOOT_SECONDARY=y to prj.conf file. And adding the following content to pm_static_dfu.yml file. But west build failed.
The following...
try to migrate LVGL
I copied from pm_static.yml from C:\ncs\v2.5.2\nrf\applications\nrf_desktop\configuration\nrf5340dk_nrf5340_cpuapp\pm_static.yml. And adding the following setting in CMakeLists...
After considerable investigation, it seems that using the nRF5340 + nRF7002 combo with some realistic WiFi client comms enabled (eg. using MQTT) results in an image that's...
Hi Nordic
I had used pynrfjprog to update modem of nrf9160 for a long time. Everything ran well and smoothly.
But, yesterday, I found it failed to update modem. I have...
currently I am working on a private project where I need a small OLED Display. Therefore I bought a 0.96" OLED Display (128x64) with a SSD1306 IC Driver on it.
First...
