Hello everyone,
I'm presently working on a project that employs the nRF Connect SDK 2.6.0 in a Bluetooth Mesh application. My task involves a requirement to increase the...
I am dealing with a persistent I2S RX overrun issue in the nRF5340 audio application that is impacting data reception and disrupting communications between the gateway...
Hi Support Team,
I'm using nRF5340-DK and the netCore was used for the BLE controller only, the appCore was used for the BLE host and my application.
The below cmake arguments...
I want to program a nRF52840 as RELAY NODE.
If I set CONFIG_BT_MESH_RELAY=n in prj.conf, with nRF Mesh app on my smartphone I see that Relay feature of the node is...
I am using the latest version (v4.0.4) of the app Bluetooth Low Energy when I select the device the page loads for about 1s and then the page gets white again. I also tried...
Greetings
I am trying to measure the current consumption of my board (does not use a Nordic SoC), and the power profiler in unison with the NrfConnect SDK app measures current...
in NRF5 SDK , i can set CLE(Connection event length extension) equal to Gap event length . but in the NCS SDK , I can't find the relevant Settings . The third lesson 3 in...
What is going on here?
I'm trying to get the central_uart example to run on the xiao ble sense nrf52840 board but uart_init() fails when trying to set the callback:
We want to use a nrf52840 as a logic controller which reads data from Modbus RTU Sensors (as Modbus RTU Master) and simultaneously is the Modbus RTU Server for an...
I need to capture the data packet transmitted by ble from my phone (acting as Central), I followed the Bluetooth LE sniffer example and was able to capture the data...
in my application (SDK 16.0.0, nRF52840) I perform a DFU and successfully update the application firmware. However I have noticed that from the moment when the DFU...
I've followed the reference circuitry pretty explicitly ( here ), however, I want to confirm that this configuration will give me DCDCEN1 capability for power supply consumption...
Trying to connect an nrf52840 based board to a nrf9160 DK via the J-Link out but always get the following error. Work as expected if I use a nrf52 DK.
Initialising nrfutil...
I've a working application on nRF52811 SDK / S140 running BLE. I need to extend it so that from time to time BLE switches off temporarily, to send a simple and short...
Hello, I have recently designed a custom board integrated with nrf7002 and nrf52840 qfaa. However, I'm encountering an issue while trying to program the nrf7002 OTP. The RTT...
We have implemented a simple contact switch using the nrf52840 and the latest zip generator (v99). The device connects to a Samsung Smart things edge router. A contact device...
OS: Ubuntu 20.04.6 NCS SDK: 1.6.1 Segger: 5.50c
I recently got a new laptop, which I installed using the following guide:
https://developer.nordicsemi.com/nRF_Connect_SDK...
Hello everyone,
I am a BLE beginner and have some confusion about the IQ data of Bluetooth AOA. I used the example direction_finding_connectionless_rx and direction_finding_connectionless_tx...
Hello, there seem to be a lot of technical details missing from the datasheet. In my case, I really need to know the capabilities of the load switches such as reverse current...
Hi there
I'm working on nRF5340 chip and looking for a way to preserve the factory data that is saved in factory_data region. I tried playing around with the factory data...
