We just upgraded to NRF V2.6.0 and ran into the following build error when building the Matter light_bulb sample:
CMake Error at /opt/nordic/ncs/v2.6.0/zephyr/cmake/modules...
I have some questions regarding the RF path of nrf5340-CLAA (WLCSP package):
1. The impedance of the transmission line in the reference design, as calculated using AppCAD...
SDK: 17.1.0
Chip: NRF52832
IDE: Segger Embedded Studio v5.10d
Developing a bluetooth accessory app for a scale on the NRF52832. Using the ble_nus SDK module.
When...
Hi Nordic team,
I hope this message finds you well. I am currently working on developing applications for custom boards utilizing the nRF Connect SDK v2.4.0, with a particular...
I am trying to build the Serial lTE Modem example from SDK directory C:\ncs\v2.5.1\nrf\applications\serial_lte_modem in VScode then resulting the error:
-- Found...
Hello Nordic Engineer,
I used SDK17.1.0
First chip is examples \ ble_central_and_peripheral \ experimental \ ble_app_multirole_lesc
Second chip is examples \ ble_peripheral...
Hi, i've been trying to use the external flash memory to store new images for OTA firmware update but i keep getting this error
*** Booting nRF Connect SDK v2.5.2 ***...
Good Day.
I'm trying to run the "npm1300_fuel_gauge" example on a custom board (nRF52840), but I'm getting errors that I don't know how to fix.
The first thing I did was...
Just upgraded to NRF v 2.6.0 (Mac OS; VS Code). Our code previous built and ran successfully on our custom board with v 2.5.0 of the SDK.
Now we get the following error...
Why is the build and flashing so slow with the nRF5340 and Zephyr? Is there anyway to make it more reasonable?
I have been doing embedded for years and I have not seen a...
I was trying to figure out what what code was being ran before main() function. Specifically the code was not getting to my main() function and was stuck in the cpu idle code...
Hello, I've trying to build BLE and MCUBoot Bootloader for a nRF52840 board (Particle Xenon) from the nRF Connect sample "Peripheral LBS". Without MCUBoot Bootloader, the...
I was wondering if there is away to perform DFU using SPI without smp protocol or mcumgr from one nRF52840 to another? What I am trying to do is to send a firmware...
SDK: 17.1.0
Chip: NRF52832
When...
I have a project working on Nora B1, which I am testing on nrf5340DK. It is based on the Peripheral UART Sample, programmed with nfr Connect SDK v1.9.1. Now I need...
Hi Nordic team,
-- Found...
We're using nRF Connect with SDK v2.4.0 (Zephyr). Central and peripheral roles combined.
Custom hardware, with Fanstels module BT840
All was working well, but after extensive...
Good morning!
I hope you will forgive my trivial question but I am a beginner. I don't quite understand the partition structure presented in the "NVS" example. Using the...
