we are developing custom hard fault handler to get its information during non-debug mode. In order to collect the information in non-debug mode we are trying to store...
I used to be able to program my development boards or my own custom boards but now I get always get an error:
C:\Windows\system32\cmd.exe /d /s /c "west flash -d c:\ncs...
After creating a directory in ncs folder, with cmake and source files, i try to add build configuration in VS code, but after the process of building occurs, the build folder...
i can't open example blinky for pca1056 in Keil C 5 in sdk _17.1.0
i have installed all package about Nordic but it isn't worked.
Beside, Can i flash code to nrf52840...
Hello, I have recently designed a custom board integrated with nrf7002 and nrf52840 qfaa. However, I'm encountering an issue while trying to program the nrf7002 OTP. The RTT...
NCS v2.6.0
nRF52 DK
central_uart send packet to peripheral_uart, then peripheral_uart send write response packet to central_uart.
How to get the write response...
I'm writing an android application, using no.nordicsemi.android:ble:2.3.1. I connect to the sensor and write 49KB data to it. Before recording, I set the desired interval...
I am having a recurring problem with NFC-CONNECT: build action. It hangs when building. Gets stuck with the following message in lower-right hand corner of screen:
The...
I need to update a custom bootloader from the main application running on an nRF52840. The bootloader is contained in 0xF0000 to 0xF90D7 in internal flash, and the S140 SoftDevice...
Accidentally used a 9V power supply. Board does not flash anymore.
Can still connect to com ports, and onboard led lights up.
Is the board fried or is it stuck in a memory...
Trying to connect an nrf52840 based board to a nrf9160 DK via the J-Link out but always get the following error. Work as expected if I use a nrf52 DK.
Initialising nrfutil...
Hi Support Team,
I want to store sensor-monitored data per minute into the QSPI flash(mx25r6435f) on the nRF5340 DK, and send these data over LTE/mqtt per day. Could you...
We want to use a nrf52840 as a logic controller which reads data from Modbus RTU Sensors (as Modbus RTU Master) and simultaneously is the Modbus RTU Server for an...
I have developed a USB MIDI application, in which I have deployed USB Device functionality through USB C-type connector. However, when I test the USB virtual COM Port...
I have an old nRF9160DK from few years back (v0.8.2). I got busy with other things and was not able to work on it.
Now I'm trying to update the modem firmware to the...
I am working on a custom PCB that involves the NRF5340 and our first iteration of PCBs had soldering issues during assembly for the nRF5340. The nRF5340’s footprint...
I'm using the nRF52840 and the nRF5 SDK 17.1.0.
I can enable extended advertising with the following program,
but my scanner is unable to scan the extended packets....
Hello Nordic Semiconductor Support Team,
We are trying to update application using DFU. We use bootloader, BLE 5 long range coded phy. DFU is not successful, please find...
